Question about Spy Vehicle Parts & Accessories
Why is my indicaters stayiing illuminated all the time there on as soon as i turn the key and the blue alarm light stays flashing?
5 Related Answers
Anonymous
SOURCE: HBM 750 BLUE LIGHT STAY ON
I have the same model, and if you turn it on and the light stays on, usually after a flash and about 10 seconds, your headset isn't paired with your phone. You need to re-pair it with your cell phone, the code is 0000. That should work.
Posted on Aug 06, 2008
Anonymous
  • 24 Answers
SOURCE: airbag light on instrument panel flashes then stays illuminated
Some vehicles you can disconnect the battery for 10-20 mins and it usually resets a check engine light. But the airbag light is different. This means there is something wrong with the airbag system and it will not go out until maintenance.
Posted on Mar 30, 2009
Anonymous
SOURCE: Have a 2000 VW Beetle. The alarm won't turn off!
My 2000 Beetle does same thing (although not all the time). Just found an internet post that suggests there is a problem in the door lock sensor. I assume you are using a regular key - not
the keyless entry - like I am. He also said that you can disable the alarm (also disables the
keyless entry - which doesn't bother me) by leaving the front door AND the rear trunk open and
starting the car up. Seems to work so far. I will get the door lock sensor replaced and turn the
alarm system back on (not sure how yet), and let you know if that stops the problem.
Posted on Jul 24, 2009
Barry Nixon
  • 103 Answers
SOURCE: battery indicater light just flashes and scooter
how many times do the lights flash?
Posted on Nov 10, 2009
Anonymous
  • 117 Answers
SOURCE: it tries to turn on. sound turns on for about 1
sounds like a power supply fault on main board
Posted on Dec 16, 2009
Red flashing light under dashboard to the left of steering column
It's an LED for an aftermarket alarm system, it means the alarm is armed, remove the key from the ignition and push the button on the back and hold it in, turn the key to on and wait until the light stops flashing, turn the key off and remove it, the next time you turn the key on the light should stay off
Mar 09, 2012 | 2008 Toyota Prius
Left turn signal will not work, cycle ignition swith light will flash
Hi Gary, you can either take it back to the dealer or try an alarm reset, for more information about your question please visit the websites below. Good luck and have nice day.
Set Change Override Transport Harley Security Alarm PIN Code No Key Fob...
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Feb 21, 2012 | 2011 Harley Davidson FLHTK Electra Glide...
Error light in my apc smart ups sc 1500va ups
1. Four beeps every 30seconds (On Battery LED will be illuminated)
This alarm indicates that the Battery PowerSupplied outlets are now supplying battery power as opposed to power from theutility. If the UPS determines that the input utility power is unsafe for yourcomputer equipment, the UPS will switch to battery power.
Note: Ifthe power disturbance is brief, you may only hear one or two beeps.
2. Continuous Beeping (On Battery LED will beilluminated)
This alarm indicates that a Low Batterycondition has been reached and that the UPS will soon shutdown. Once the UPStransfers to On Battery operation, it can only stay on battery for a limitedamount of time. The UPS will sound this alarm about two minutes before thebatteries are totally exhausted. Once exhausted, the UPS will shutdown and turnoff its output power to your equipment. If you hear this tone you shouldimmediately shutdown your computer to prevent data loss or corruption.
3. Continuous Beeps for 30 seconds (BackUPS OFFICE 250 and 280 ONLY)
This alarm indicates the unit has detected anOverload condition after it has performed a self-test during start-up.
4. Continuous Two-Tone Beep
This alarm indicates a severe Overload wasdetected while the unit was on-battery operation. This tone will continue tosound until the unit shuts down.
5. Continuous Tone (On Battery LED will beflashing)
This alarm indicates that the battery-poweredoutlets are overloaded.
6. Continuous Tone (On Line and On BatteryLEDs flashing) Back UPS OFFICE 350,400, and 500 ONLY
This alarm indicates that an internal UPS faulthas occurred.
Dec 08, 2011 | APC Smart-UPS SC 1500VA UPS System
Flashing alarm light after battery change. Car wont start,
System operation
System arms 5 seconds after switching ignition OFF. Switch ignition ON. Ensure clock LED illuminates for 3-5 seconds. If LED flashes rapidly at regular intervals for approximately 1 minute, then flashes at irregular intervals: Key code not recognised. Remove key and try again.
Programming
When
System malfunction: LED illuminates for 1 minute, then flashes at irregular intervals. Key(s) added or replaced.
NOTE: Replacement keys MUST have blue mark. Keys with red mark are NOT compatible with this system.
How
NOTE: Programming method using vehicle keys can be deactivated using diagnostic equipment.
Obtain 2 programmed keys (A and B). Insert key A into ignition switch. Turn ignition switch to position II. Wait 1 second. Switch ignition OFF. Remove key A. Insert key B into ignition switch within 5 seconds. Turn ignition switch to position II. Wait 1 second. Switch ignition OFF. Remove key B. Within 10 seconds: Insert key to be programmed into ignition switch. Turn ignition switch to position II. Wait 4 seconds. Switch ignition OFF. Wait 5 seconds. Start engine. If engine does not start and clock LED flashes: Switch ignition ON. Wait at least 20 seconds. Switch ignition OFF. Repeat programming procedure. Repeat above procedure to program remaining keys. Keys can also be programmed using diagnostic equipment
Mar 08, 2010 | 2000 Ford Focus
Maintenance light flashing
h) Engine Oil Replacement Reminder
Light (for vehicles sold in U.S.A.)
This light reminds you when to replace
the engine oil.
This light will come on when the ignition
key is turned to “ON” and will go off after
about a few seconds.
When you drive for about 8000 km (5000
miles) after the engine oil replacement,
this light illuminates for about 3 seconds
and then flashes for about 12 seconds
with the ignition key turned to “ON” position.
If you continue driving without the
engine oil replacement, and if the driving
range exceeds 12000 km (7500 miles), the
light will come on after the ignition key is
turned to “ON” position. The light will remain
on thereafter.
If the light is flashing, we recommend that
you replace the engine oil at an early
opportunity depending on the driving and
road condition. If the light comes on, replace
it as soon as possible.
You need to reset the light after the engine
oil replacement. Reset the light by
following the procedure below:
1. Turn the ignition key to the “OFF” position
with the odometer reading shown.
(For details, see “Odometer and two
trip meters” on page 136 in this Section.)
2. Turn the ignition key to the “ON” position
while holding down the trip meter
reset button.
Hold down the button until the light goes
off. Before the light goes off, it illuminates
for 3 seconds, flashes for 2 seconds and
illuminates for 1 second.
If the system fails to reset, the light will
remain flashing.
I copied this from page 143 of the owners manual for the 2004 4Runner
Jun 04, 2009 | 2004 Toyota 4Runner
On my saab vector ignition key functions
I have a Saab 93 Vector and although my key does not have that function my manual says the following; 'Press once - Turns on exterior and cabin lighting, for 30 sec, or turns off lighting. Deactivates panic alarm. Hold and press for more than 2 sec - Cars with car alarm: panic alarm (activates alarm manually).
There is another section that says the button turns off lights and larm when activated and the car remains locked. The panic alarm can only be activated when the car is stationary and it will be silenced when the car is driven away.
Hope that makes sense. Enjoy your Saab 93 - I know I do every day.
Tony
Mar 31, 2009 | 2004 Saab 9-3
Alarm red light stays on after you shut the car off 1998chrysler
I would turn the key on without starting the car then press and hold the black button till the alarm light flashes.Then turn key off take out of car and try the fob again.
Mar 29, 2009 | 1998 Chrysler Cirrus
ELECTRICAL MISTERY
Here's a first step: Put key in ignition, turn on but do not start car. When dash lights up, the alarm light will flash if it has been triggered. If this alarm light is flashing, you have set off the alarm. Here's how to reset it: Leave key on, and let the thing flash for five minutes or so. Finally it will stop flashing on its own. Now start the car. If it runs ok. Kill it and turn key back on to check if light has stopped its flashing. This may be way off, but that is the reset procedure for alarms on those blazers. Man I've seen a bunch of them in my shop this year!!!
Mar 20, 2009 | 1996 Chevrolet Blazer
"Change oil soon" light
Turn your key to the on position wait until all of your indicater lamps do their thing . Then pump the gas pedal 3 times in rapid motion in less than 5 seconds. Wait until you see the change oil light start flashing. If this does not happen then turn the key off turn it on again and repeat the procedure.
Jan 30, 2009 | 2005 Buick Century
Focus remote key fob not working
this info would cost you £30.+ at ford Radio Frequency Programming Instructions:
  • Insert the ignition key and turn from position II (Ignition) to position 0 (All off) and back four times within three seconds.
  • Remove the ignition key. The locking control system is now in "learn mode" for the next 20 seconds and the red warning system LED (By the clock) stays on continuously to indicate this.
  • During the 20 seconds press one of the transmitter buttons. The remotes signal and code number is learned by the locking module and is indicated by flashing the warning system LED.
  • Wait until learn mode times out (20 seconds) or switch the ignition back to ON.nfrared Programming Instructions:
  • Put your key into the ignition and turn to position 1 (Radio). After approximately 10 seconds the red alarm control LED (next to the clock) should illuminate. As soon as it comes on remove the key from the ignition - the LED should remain lit.
  • Point the remote's "eye" at one of the front door sensors and press the rear button until the light on the transmitter illuminates (Keep the button pressed)
  • With the rear button held in press the front button 4 times then release both at the same time. The control lights in both clock and fob will flash 4 times to indicate programming complete.
  • Turn the ignition back on to exit programming mode
Nov 28, 2008 | 2000 Ford Focus
Vehicle Parts & Accessories Logo
Top Spy Vehicle Parts & Accessories Experts
Colin Stickland
Colin Stickland
Kardoc
Mr.Mike
Are you a Spy Vehicle Part and Accessory Expert? Answer questions, earn points and help others
