Question about Samsung SYNC SGH-A707 Cellular Phone
Bluetooth hi i am trying to connect my motorola hs850 bluetooth headset with my samsung a707 and not having any luck :(any help appreciatedthank you
Posted by korki on
  • Anonymous Jul 15, 2008
    cannot connect a motorolla h500 to my samsung sync
Anonymous
Hello iam having trouble activating my bluetooth
Posted on Jul 15, 2008
I have tried everything . My Motorola Hs850 will not connect. It keeps indicating that the connection failed
Firstly, make sure you have enabled Bluetooth on your phone or whatever device your using the headset with. The default setting off, so go into your phones set menu and enabled Bluetooth.
You'll then need to 'pair' the headset and phone.
1. Ensure the headset is turned off (indicator light not blinking).
2. Press and hold the Call E button for 4 or 5 seconds. The indicator light will initially flash, but continue to hold down the button until the indicator light is steadily lit.
If the indicator light is flashing or not steadily lit when releasing the button, repeat both steps 1 and 2. Hold the Call E button for 4 or 5 seconds.
3. Enable Bluetooth on your phone and get to 'search for devices' it should find the headset.
4. Select Motorola HS850
Select OK or Yes to pair your headset with your phone. Enter the passkey: 0000 Select OK. When your headset successfully pairs with your phone, the indicator light changes from steadily lit to flashing.
Hope this helps. Oh and make sure your phone actually supports the headset!
Jun 13, 2011 | Motorola Mobility HS850 Consumer Headset
Need instructions for connecting ear piece to iphone 4
Hi,to complete the look of a tech-savvy, iPhone-using individual, you must have a Bluetooth headset to accompany it. You can pair any Bluetooth headset with an iPhone. The Motorola HS850 is no exception to this. Both Motorola and Apple's Bluetooth set-up process is fast, so you'll be talking with people through your new Bluetooth on your iPhone in a matter of minutes.
Instructions
Charge the Motorola HS850 headset fully before attempting to pair. Usually, it takes two to three hours to charge the headset.
Press and hold the "Call" button (has a phone icon on it) on the headset for six to 10 seconds. The outside LED light will turn on indicating that the phone is in pairing mode.
Choose "Settings" on the iPhone homescreen.
Select "General," then "Bluetooth."
Select to turn Bluetooth on.
Wait for the phone to search for in-range devices.
Select theMotorola HS850 from the list of devices.
Enter the headset passkey to complete the pairing. By default this is "0000."
Have a nice day..
Feb 23, 2011 | Motorola Mobility HS850 Consumer Headset
Can't connect a motorola hs850 with a samsung m520.
How to pair a Motorola HS850 bluetooth headset How to place a Motorola HS 850 bluetooth headset into paring mode:
  1. Close the boom to turn the unit off.
  2. Hold down the call button until the blue light comes on.
  3. While holding down the call button, swing the boom open.
The headset is now in pairing mode, and you can search for it using your phone. When it asks for a PIN, use 0000.
Jun 23, 2009 | HTC G1 Smartphone
Having problems pairing
Apr 12, 2009 | Motorola Mobility Universal Wireless...
People can hear me hs850
try re - pairing the headset with your phone. Delete the older paired profile from your phone before re pairing.
Good luck
Aug 20, 2008 | Motorola Mobility HS850 Consumer Headset
PAIRED MOTOROLA BLUETOOTH WITH SAMSUNG
hold down the connect button on the bluetooth tl the light stays on, then open the boom, release the button. The light should stay on now, and your phone should be able to find you bluetooth.
Jun 18, 2008 | Motorola Mobility HS850 Consumer Headset
Motorola H350 connecting to my samsung
well idk cuzz i cant connect it with my samsung SGH-A707
Apr 17, 2008 | Motorola Mobility H350 Wireless Headset
Motorola HS850 Bluetooth headset
no u need to take it to phone manufactuer
Jun 28, 2007 | Motorola Mobility HS850 Consumer Headset
Samsung A900 and Motorola HS850
Have U tried re-link them? Turn off both device. Then switch the cell phone on first and check if the bluetooth is on. Then link it with the bluetooth. If you lost the manual, search online on the steps to do the linking. Cell phone should be able to detect the bluetooth and finally link with it.
Aug 25, 2006 | Motorola Mobility HS850 Consumer Headset
Samsung SYNC SGH-A707 Cellular Phone Logo
98 people viewed this question
Top Samsung Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
John Tripp
John Tripp
Ekse
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
