Canon PIXMA iP4200 InkJet Photo Printer Logo
Question about Canon PIXMA iP4200 InkJet Photo Printer
CATRIDGE SENSOR DISABLE
Xerox 7335 Yellow Drum catridge did not shows.. Catridge is perfect but did'nt shows...
Make sure deal has been removed pull out press cancel 30 seconds...power off on the put back in
1helpful
Hi I bought a lexmark S405 and when my ink finished, i decided to refill the black catridge but the print wont print unless i buy a new catridge which is expensive than buying a new printer. I wanna...
The Lexmark S405 printer requires all cartridges to have ink in them to continue printing.
The 100/100XL cartridges are not licensed to be refilled. You can, however, refill the 100A or 100XLA cartridges available on the Lexmark website at http://www.lexmark.com. You should be aware that a refilled cartridge will not be able to report its ink level, and you might not get the print quality you expect from ink that is specially formulated by Lexmark to pass through microscopic nozzles at extremely high temperatures.
I've got a HP laserjet 1012. I have placed a new print cartridge 12A black, but my computer still give the message "toner empty" and my printer have still the flashing red light. What i have...
I wont think so that there is no toner level sensing in 12a catridge, messaige might be catridge missing or incert catridge.. remove back door see down right side sensor which sensing the catridge presence, check sensor flag dislocate/spring dislocate/broken correct it, if sensor is dusty clean it... Best of luck
MY PRINTER IS NOT PRINTING, the rest of function is working only priting left and its got catridge ligning problem help
OFF the printer and remove both catridge, clean the catridge sensor in the printer with a sprite, after some few minute ON the printer while it is connected to the computer.
Then OFF the printer again and reinsert the both catridge back appropriately.
Finally, ensure that the printer is the default and not offline.
Best regards.
The printer (Lexmark X5340) display "cover open"
Short of slamming the cover closed there is a small tab that tells if it is open or closed. It should be located on the lower right hand corner. Once you find it just put a small piece of paper there or plastic and you should have no more problems.
Printing not clear & disabling alignment
h o this is because of the catridge problem. check the outlet of the ink....and clean the area with proper clean cloth and check t. may be the catridge got over . so check the level and try printing.
2helpful
2answers
Cartridge Error
The only step is to perform a Full reset on printer
Disconnect power cord from back of the printer ( when printer is ON )
while holding the # and 6 button connect the cord back
It has to go thru cartridge alignment process, if this does not work, there is problem with printer hardware.. or you can contact HP Support too
2answers
Printer
install it using the latest driver from hp's website and then after its installed right click on it and go to properties and on the ports tab disable bi directional support and on the advanced tab disable advanced printing features ( both are checkboxes that need un checking )
if that does not work contact hp
1helpful
Refilled cartridge problem
There's some kind of a chip chip in the catridge that notifies the printer that the same cartridge has been refilled. to get around this check keep atleast 2 or 3 empty cartridges, refill and cycle them. That should do the trick!
2helpful
Hp j5780
access door means the door used to replace catridges,it pushes the sensor arm which enables or disable the door sensor,so u better check for thesensor arm connecting properly,try to push the door n check
thnx N
Clive
Clive
old marine
old marine
