Question about Jenn-Air JED8430 Electric Cooktop
Why are lights not working under the ceramic JennAir stove top?
Removed cooktop to replace counter top. Replaced. Burners work but lights not working.
Posted by Sara-Anne Polit on
rayreidblack
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 117 Answers
You have probably accidentally disconnected some wiring whilst moving it need to re explore
Posted on May 10, 2014
5 Related Answers
SOURCE: wire for stove top burners
same place you got the switches,you can usually get the whole harness.
Posted on Dec 06, 2008
erica graber
  • 530 Answers
SOURCE: Romvoing the top of my Whirlpool Cooktop
well usually you have to remove the knobs. thentake all of the caps off of the burners. sometimes there are scres that hold the burner caps on. make sure you turn the power off. Then after you have done this the glass should come right off. If not there may be screws under the cooktop. Do these first steps and let me know how it goes.
Posted on Jan 18, 2009
Maytag317
Victor
  • 1136 Answers
SOURCE: I cannot REPLACEMENT KNOBS fOR model # 5D02
Hi, The part #74009592 for your knobs. This # is for a black knob. Let me know if I can assist you further.
Vic
Posted on May 24, 2009
gerbee gomez
  • 222 Answers
SOURCE: Electric ignitor does not work at all on Jenn-Air Gas cooktop
need to replace the ignition coil.no adjusment the unit is power operated 1st check the plug,outlet or main swicth sometimes not properlly connected.
Posted on Jun 23, 2009
Fred Yearian
  • 5603 Answers
SOURCE: How to repair cracked corner of black ceramic cooktop
Epoxy would not work. If it is a very small chip and is NOT STRUCTURAL or in the heated are you could TRY the adhesive used for rear view mirror to glass attachment.
Posted on Sep 14, 2009
Burners ceramic top stove
FIXYA has no agents and have no idea who can assist you there
Dec 15, 2017 | Creda Cooktops
Maytag ceramic top stove with the double oven, two small burners don't get hot anymore can I fix myself and how?
It is simple . Before the process make sure the the power is off .. There screws on the back after removing them you can lift the top n easily remove the none working ones . You can buy the spear ones online or local shop . I have done it myself or search YouTube with model number youse come a cross with repair option . Good luck .
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sam_bbe602d2c68da69b
Aug 06, 2013 | Cooktops
How do i replace my burner on my jenn air ceramic cook top . it has the down draft feature in the centre
1) turn off power at the breaker. 2) remove hold down screws 3) pop up cooktop out of counter top 4) remove knobs and downdraft grille 5) remove ceramic top (screws around outside and also in side grille opening) 6) unplug burners replace with new burner
Sep 17, 2009 | Jenn-Air JED8430 Electric Cooktop
One of the burners won't light. The stove top is ceramic electric. It is a Magic Chef oven. Other three burners work.
check all wires to burner and switch. If they are good .....burner burnt out or switch no good.
Aug 05, 2009 | Cooktops
Stain on burners
Use DeBruce Polish on ceramic cook tops, go to debrucepolish.com
Feb 06, 2009 | Jenn-Air JED8430 Electric Cooktop
Ceramic Glass broken
when ordering you would have to know the color also
Dec 05, 2008 | GE 30 in. JP340 Electric Cooktop
All 4 burners stopped working - circuit breaker ok
How old is this cook top stove? Does it require replacement?
Jun 11, 2017 | GE 30 in. JP385 Electric Cooktop
Stove top [gas] JENNAIR
Try carefully cleaning around the ignitors. Also clean hole in burners. Clean the holes closest to ignitors. This can be caused by a crack in ignitor, this requires replacement.
Nov 05, 2007 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Jenn-Air JED8430 Electric Cooktop Logo
111 people viewed this question
Top Jenn-Air Cooktops Experts
Marvin
Marvin
Paul Carew
MARLON KELLER
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
