Monitor worked great, then had heavy yellow tint, and now green tint that I can not balance to pure white.
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
SOURCE: monitor color changed
Assuming you can rule out the PC and the cable (are the pins ok?) then it sounds like it needs component-level electrical troubleshooting.
SOURCE: centering your monitor screen
Check your resolution and change them. This happens sometimes when a monitor can not handle certain resolutions.
SOURCE: monitor screen changes from regular color to a green tinted screen?
Is the cable connected securely? You may need to check your video card also. You may be able to disconnect the cable and get a red, green, blue icon on the screen. If that appears normal then there is nothing wrong with the monitor itself, it may be the cord or the video card.
Hope this helps!
SOURCE: Monitor Flashes Colors when system powered down
Reset factory settings. Push the selection button (second button from the left at the bottom of the monitor, next to the AUTO button), then go the the Factory Reset by pressing the minus button. Press the selection button again, and when it asks if you want to reset say YES by using the minus button. It's a quick fix!
SOURCE: Monitor displaying yellow tint
Hay guys make sure your video card is seated and fastened properly and the connection for the monitor is secured firmly, worked for me.
Dbox
