Question about Pentax Optio S50 Digital Camera
Turning flash on and off
I lent my camera to a friend who turned the flash off. How do I turn it back on? Thanks.
Posted by bwooster on
Anonymous
    Problem Solver:
  • 9 Answers
Turn the camera on. Then on the circle around the ok button there is a picture on the left hand side of a flash. Press that til the same picture shows up on the display. It will stay on til you change it again.
Posted on Apr 21, 2008
Cobra DC6425
hi friend
plug ur camera in ur pc load ur camera driver & earse ur all camera photos u can use ur cam as pan drive
Mar 31, 2008 | Nikon D70s Digital Camera
Could not start the camera. Close other applications and try opening the camera again
DEAR FRIEND, TRY SWITCHING OFF YOUR PHONE AND TURNING IT BACK ON. IF THE PROBLEM STILL OCCURS THEN YOU WILL HAVE TO RELOAD YOUR PHONE WITH A FLASH FILE.
Feb 09, 2011 | Cell Phones
Hi I have a makita drill 18 volt. I lent the drill to a friend and got it back not working properly. When I squeeze the button, the motor is running but the head of the drill is not turning and doesn't...
Check the speed control. There is a speed control usually from hi to low... sounds like it's in between speeds... try adjusting it back and forth...
It should go back into one gear and work fine.
Oct 06, 2009 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Turn Off Flash
press on the button with the right arrow, next to the cammera's display. you will see that the flash icon on the screen now shows a circle with a bar across it
Jan 19, 2009 | Panasonic Lumix DMC-LS1 Digital Camera
The lens is blurry and makes a buzzing noise when turned on
Well all the moving parts of the lent are plastic and most likely the reason Y you hear that sound it's because one of the hummmm the tiny wheels , that are connected to the mechanism of the focus on the lent is busted..... so replace that.
(some times if you take the camera to the beach the sand get to the mechanism ans stock the wells. In that case cleaning of the lent will suffice)
Now parts are not that easy to find some times companys only sale the complete lent and it will cost you, in that case you will need to decide if "REPAIR" or "BUY NEW" camera will be better
Jul 13, 2008 | Casio Exilim EX-Z77 Digital Camera
Screen only shows "access"
One of my friends has the same problem with her camera, but we can't even get old pictures to come up on the screeen. When you turn it on it says access for about 15 seconds, then tells you to tell the camera off and then back on.
Aug 22, 2006 | Sony Cyber-shot DSC-W70 Digital Camera
Pentax Optio S50 Digital Camera Logo
41 people viewed this question
Top Pentax Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
halotheracer
halotheracer
Are you a Pentax Camera Expert? Answer questions, earn points and help others
