Question about Select Jazzy Used Electric Wheelchair
Why is my merits DL 5.2i stuck in low speed ?
The chair was running fine yesterday I disconnect the joystick an plugged it back up. I kept it on high speed and the chair running slow I even put a brand new battery in
Posted by Marcus Robison on
ALLmobility
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 67 Answers
You may have a thermal rollback issue. Try charging the chair overnight and leave the controller on while charging. This will give the control module/joystick time to reset themselves. Thermal rollback happens when a certain temperature in the motors is reached. The system shuts itself down to protect from damage.
Posted on Apr 30, 2014
1 Related Answer
Anonymous
  • 6 Answers
SOURCE: new batteries chair slow
The amber lights just below the charge indicator have 5 steps. pushing the buttons once only moves it 1 time in the direction of the button pushed. Make sure that all 5 lights are on. The chair is only geared for about 4 to 4.5 MPH, That is about average walking speed. Good luck.
Posted on May 12, 2010
How do we charge this chair?
off board chargers plug into the front of the joystick. after 10-12 hrs the chair should be charged, Unless the batteries are bad, or the charger is bad. Plug into joystick before power cord into wall outlet. also charge every night!
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
Mar 15, 2016 | Health & Beauty
How do I speed up a Merit Vision Sport?
As the user of the chair, you will not have the ability to speed up your chair unless you have the specific programmer to raise the speed. Typically mobility specialist will turn your speeds down until you get used to the chair and then come back out when you are capable of driving chair at faster speeds. You will have to call the dealer who slowed it down or, another DME company in your area to have the chair speed adjusted.
Apr 30, 2014 | Merits Health Vision Sport Power Chair -...
Have replaced joystick and motor controller, but chair turns left when joystick is moved to right. also, motion seems eratic,what can I do????
sorry to tell u this but with a new controller and joystick u will need a tech with a programmer to redo the joystick and det up controller,so contact a dealer for help
Oct 24, 2013 | NRS Used Merit MP 3CR Power Wheelchair
Hand control flashes right to left on my merits power chair
Your joystick is in lock mode. Call Merit to find out how to unlock it or a power wheelchair dealer.
Nov 23, 2012 | Electric Health & Beauty
I BOUGHT A USED JAZZY JET 3 ULTRA WITHOUT BATTERIES AND I HAVE BOUGHT 2 NEW BATTERIES BUT AM NOT SURE HOW THE WIRES HOOK TO THEM, IF THE 2 BATTERIES HOOK TOGETHER.
Locate the two wires from the circuit breaker attach one wire (black if marked) to the negative post of the rear battery and attach the other wire (red if marked) to the positive post of the front battery. Locate the two wires coming from the power module plug with a red and black wire. Attach the red wire to the rear battery positive post and the black wire to the front battery negative post. attach the joystick to the nine pin plug at the rear of the chair and turn it on. You should have power at the joystick and the chair should work. Disconnect the joystick put the shroud cover back on grease the seat post and reattach the seat then plug in the joystick and charger plug at the rear of the chair. Charge the batteries before use and charge them overnite for the next 20 days. If you use the chair daily charge your batteries everynite while you sleep unplug in the morning. If you don't use the chair daily charge at least once per week or after you use the chair. Always put the chair up fully charged if you are going to be out of the chair for an extended time the disconnect the batteries at the large plug going to the power module Hope this helps you
Apr 13, 2011 | Jet 3 Ultra Power Chair
I need to know how to charge the batterie om my sisters merits wheelchair,i do not know how to plug it up,,or if the charger is located on the frame someplace or if its freestanding.plain and simple i do...
sking the off board charger is a 5 inch by 3 inch rectangular box with a power plug on one end and a round silver 3 prong plug on the other. The charger plugs into the charger port located under the front of the joystick. Plug the charger plug into the joystick and then into the wall socket. When it is fully charged the light on the chrager will turn from yellow to green. Unplug the power from the wall socket first then unplug from the joystick In ither words always have the charger unplugged when you plug the charger up to the chair Now if the chair has an onboard charger there should be a power cord that just plugs into the chair usually somewhere in the rear of the chair all you have to do is plug it into a wall socket and charge away Hope this helps you
Mar 10, 2011 | Electric Mobility Merits Electric...
Speed lights flash alltogether at the same time chair will not run
The chair is in sleep mode or lockout mode. To unlock-- turn on the chair, immediately push the joystick straight forward until you hear a beep then push it straight back until you hear another beep then release to center. This should unlock the joystick. Turn the chair off then back on and you should get normal operation Hope this helps
Jan 27, 2011 | Pride Jazzy 1113 Power Chair
The chairs lights are flashing from right to left on the joystick which is call the sleep mode can not get it to reset.
Hi to unlock the shark joystick turn on the chair and press the horn button twice within 10 seconds of turning it on. This should unlock it for you. Hope this helps
Jan 23, 2011 | Electric Mobility 24 " Seat Merits Heavy...
The chair will turn on with the push button but will not turn off. Have to disconnect controllor. Otherwise runs fine.
rblome You have a bad switch on the joystick. Now its not really the switch but the switch button. Under the button there was a metallic coating that makes contact with the cicuit board switch turning the chair on and off. If that coating gets worn then the switch doesn't wanna act right. Now if you feel creative and don't want to order a new faceplate then you can carefully peel the faceplate off the joystick (just far enough to expose the bottom of the on/off switch, put a small block under the faceplate to keep the bottom exposed) and taking a small piece of foil glue it to the bottom of the on/off switch. after it dries trim the foil to fit the size of the switch bottom and disconnect the joystick cable at the rear of the chair and carefully reinstall the faceplate making sure that you get the switch into its hole in the joystick. You might have to put a small dab of glue to the top of the faceplate that rests on the case to keep it down and in place. (Now I didn't tell you how to do this its our secret) plug the cable back in and try the switch it should work fine but it will be sensitive to turning on/off. Hope this helps
Nov 18, 2010 | Invacare Pronto M51 Power Wheelchair
Wheelchair will not run. lights blink on and off
may have damaged one of the two motors or disconnected motor plug.
Mar 24, 2009 | Electric Mobility 24 " Seat Merits Heavy...
Select Jazzy Used Electric Wheelchair Logo
171 people viewed this question
Top Select Health & Beauty Experts
Rob Hill
Rob Hill
Lawrence Oravetz
Are you a Select Health and Beauty Expert? Answer questions, earn points and help others
