Question about Tablets & eReaders
How can I fix the RCA 7in power port?
My son stuck a mini screwdriver in the power port and now the plug won't go in. Is there a way to replace the port and where can I find the part? Is there a way to charge it with the mini usb?
Posted by Kathy Myers on
Mike Miner
    New Friend:
  • 19 Answers
You should be able to charge it with the mini usb port on the tablet. Just plug it into a regular wall or car charger with your data cable and it should start charging.
Posted on Jan 26, 2015
DR NITIN KHANDELWAL
  • 383 Answers
You should contact Authorized Dealer or Service Center to get it serviced.
Posted on Apr 26, 2014
How do I recalibrate my 7in rca
'recalibrate' in what way? Voltage, screen resolution, volume level, what?
Feb 19, 2016 | RCA RCT6077W2 7" 4 GB Black Wi-Fi Tablet...
Tip
Power Cable Popping Out on Versus Chinese Tablet
Versus Tablets (sold mostly in the UK and Ireland until 2014) have some great features (like HDMI out and Bluetooth), but power is a problem. They do not charge through the USB port, but through a 3.5mm barrel jack plug (specs are 5v 2000mA).
The power cable on my Versus Android Tablet keeps popping out (and therefore the tablet won't charge). Lately it got so bad that the plug simply wouldn't go in at all. I did a bit of research and came up with a fix.
There's a small plastic ring at the top of the plug. Take a precision pliers and pull the ring off the plug. BE CAREFUL! - If you damage the plug it simply won't go in at all, and your tablet will be useless.
Without this ring the plug stays in and the tablet charges. It still pops out occasionally, but a lot less than it did before.
NB: I do see some replacement power adapters with these plugs available on eBay and Amazon, so you may be able to try out a replacement power supply too.
Versus Tablet
on Feb 01, 2015 | Tablets & eReaders
How do I plug hdmi into tv?
Make sure that the TV is HDMI compatible first, if not then the only way would be to buy a converter cable. Older TVs won't be able to support HDMI, newer ones should have a port just like the one below:
Jan 11, 2016 | Amazon Kindle Fire HD 7in, 32GB
I can't shut my rca 7in tablet off
Go to this link on YouTube and do a factory reset and reboot. This will reset your tablet so you may be able to use it. It sounds like your system got corrupted or infected.
RCA Factory Reset Reboot Unlock
Jul 03, 2015 | Tablets & eReaders
Charging port replacement
If Your skilled to replace you should know if not take it in to store very very hard to replace.
Jul 11, 2014 | HP SLATE 7 EXTREME 4400 NVIDIA TEGRA 4 QC...
My sons tablet has insufficient memory and i have uninstalled games and it doesn't work
Plug it into the USB port on a desktop or laptop and verify the games were removed. You could just do a hard reset. Help Desk RCA Tablets
May 16, 2014 | RCA CA 7" Tablet with 4GB eory 28458515
Replace RCA 7in power port?
Contact any service technician. The set shlould be opened to replace it. It can be replaced. Gopakumar Gopalan Google
Apr 26, 2014 | Dell Streak 7 Tablet Android
Mini usb port on kobo arc is broken. Where can I get parts?
Hi i managed fix my usb port , open the kobo and remove the usb ribbon, the usb port is glued at the rear , you will see a black blob od adhesive at back of port , this comes unstuck if it gets a knock , i gently lifted this slightly then slid some super glue underneath and then applied pressure on top of the usb port to ensure the port was contacting the ribbon again until the glue set, my kobo is back in action again , hope this helps someone
Jun 20, 2013 | Kobo Arc
Wont power on
Hey, my tablet has done this as well at times. I would leave it attempt to jiggle the on and off button if possible to do so. Sometimes the mechanics under it can get stuck or become sticky and this is why its not turning on. Be persistent, took a day one time for mine to turn back on.
May 12, 2013 | Sylvania Synet7lp Mini Tablet 1.0ghz Arm...
Tablets & eReaders Logo
118 people viewed this question
Top Tablets & eReaders Experts
Marvin
Marvin
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
