You should contact Authorized Service Center. If they suggest, go for a New Remote.
It will be best to buy its original remote control. In most cases, universal remote control won't work satisfactory with Bush brand TVs. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its user manual. Never accept a remote control, that hasn't both of this. If you see the site by "MOSAIC" or "Magazine" view, will make surf easier.
http://electrohelponline.blogspot.com/
Universal remote controls are available at most of the electronic spare part selling shops.
Check this link too. http://remotesearch.blogspot.com/
SOURCE: Bought a fairly used
Hard to say what the code is without knowing the model number of the remote and the brand of TV.
RCA's website has a remote code finder you can use.
SOURCE: URC22B universal remote controller 15 in 1
081,119 or 026
worked on my bush dvd/tv combo tv part
SOURCE: Jumbo universal remote and the codes given wont
You need the sheet that came with the remote. If the manufacturer's codes do not work with your ??, then you need a more modern remote. The codes must ALREADY be in the remote to be used. The code is part of the REMOTE.
http://www.tvcodes.com/ may have the code for you.
SOURCE: How do u program Bush DFTA13HD STB TV buttons
The following is an extract from the Bush DFTA13HD/ DFTA13HDSIL user manual, page 9;
1. Press STUDY key until Red LED remains lit (for about 3 seconds)
2. Point Converter (Bush) remote control to TV remote control directly, keep the distance about 1~3cm
3. Press the "Power" key at TV/s remote control to send signal to Converter remote control. The LED light will flash till steady. Then press "Power" key at Converter remote control. It will record the signal.
4. Now the Power key can turn on/off TV/s power
5. Repeat settings of learning for the other keys
You can repeat Step 3-4 for setting of learning for the other keys at TV remote control, such as VOL /-, CH /-, and F1, F2 are reserved for any other keys you want to set up.
Note:
1. When you have finished setting the learning keys, press the STUDY key to leave the learning status, and the LED light will turn off.
2. The learning function of this remote control may not support all types of TV sets, if you still can not control your TV after you have attempted the above steps, then this remote control may not support your TV or its remote control.
SOURCE: does anybody know the remote code needed for a BUSH LY24M3 tv please? :)
For more details type in this site name "Electro-help" (DO
NOT copy and paste the site name from here.
It may lead you to wrong place) to search box of your search engine
[not in the address bar of your browser], and press "Enter". It is an electronic equipments service help
site. Note the
position of hyphen in between words in site name. The site will appear as it is in
web; subtitled as Service help to electronic home entertainment equipments.
Pull up older posts.
You can locate this site,
either at the bottom part of first search page, or at the top of second. Detailed descriptions are there to help you.
