I'm trying to install Linux and need to boot from a DVD
Judging by this review, your computer possesses a CD drive and NOT a DVD drive.
http://www.cnet.com/products/mpc-clientpro-414-all-in-one/specs/
Your best luck at installing Linux (Good choice for an old computer by the way) would be to use a USB Drive for the installation.
You should find the instructions for creating a USB Drive and for booting from live USB on the website of the Linux distribution you're trying to install.
SOURCE: Get My Drivers
The company that built the ClientPro 414 for MPC sold it to several other companies. It is also known as the Mecer Multimedia PC L19IA.
Here are the XP drivers directly from Mecer:
http://downloadcenter.mustek.co.za/list.php?dir=Repository%2FMultimedia+PC%2FL19IA%2FXP%2F
SOURCE: I reinstalled win xp pro and I get an yellow
you can download the drivers from the following link:
http://www.mpcdrivers.com/apps/filelist6233.html?ID=16781
hope you find this information helpful.
Thank you for choosing Fixya
SOURCE: where can i get a network driver for a clientpro
Also here: http://www.mpcdrivers.com/partners/partner1c06.html?ID=2
SOURCE: I NEED A SERVICE/OWNER MANUAL FOR A MPC CLIENTPRO
Try following link, looks executive file but after installation it puts up a shortcut to manual on desktop
http://www.mpcdrivers.com/sylvia/Support/Desktop/MANUALS/EMA/EMA001054-01%20Install.EXE
Also, can download from
http://www.mpcdrivers.com/apps/compdet1658.html?ID=11342
Hope this helps..!
SOURCE: where is the battery in an MPC ClientPro 414? How
The battery is fairly easy to replace on a CP414, but you need to be careful to avoid breaking the battery socket.
You will need a small Philips-head screw driver (#1, I think) and a small flat-blade screwdriver (for prying). A pair of tweezers will help too.
1. On the back of the system, remove the cable door. It is held in by 1 screw and wraps around the back/bottom of the system.
2. The battery is half-way under the optical drive. The only way to easily remove it is to remove the optical drive.
3. Remove the optical drive. It is held in by 1 screw near the bottom of the system (not the screw in the bottom-right corner of the back of the system, but the one just above that). With the screw removed you can push on the back of the optical drive by reaching in through the cable door you removed in step 1.
4. The battery has a sticker on it that protects it from shorting against the optical drive. This sticker is important, so save it if you can. If you can't save it, use some electrical tape or similar to prevent a short.
5. Peel back the end of the sticker that is closest to the optical drive frame and gently pry back the metal clip that holds the CMOS battery down. It should pop out fairly easily.
When you re-insert a new CMOS battery, make sure you insert the end under the metal clip first and then push down. Also, make sure it is properly aligned or you will probably break the battery socket.
Replacing the battery is much easier if the motherboard is removed first, but removing the motherboard adds about an hour to the whole process. If you want to go down that route, let me know and I'll give you some help.
--Russel
