Hoover MICROPHONE/DIRT DUCT - 92001064 Logo
M
Martin Posted on Apr 26, 2014
What is the purpose of the microphone in the dirt duct tube
The DIY Blonde
Level 1:
New Friend:
  • Contributor 42 Answers
  • Posted on May 07, 2014
The DIY Blonde
Contributor
Level 1:
New Friend:
Answers
42
Questions
0
Helped
15430
Points
92
Hoover uses a small microphone that is positioned in the plastic housing that the end of the hose fits into, just behind the bag compartment. What happens is that when dirt comes up the hose and hits the 90 degree corner, just before it enters the bag, the microphone picks up the sound and transmits that info to the electonics that controls the lights. Sometimes the microphone will stick and the red light will stay lit. If you take a screwdriver and give the microphone area a sharp tap with the handle of the screwdriver, this will often jar the microphone and it will begin working again. If not, it may need to be replaced. NOTE: this function does not affect the cleaning efficiency of the vacuum. Your vacuum will still work normally whether the dirt sensor is working or not. It is a totally unrelated function to the vacuum itself.
Hoover troubleshooting
Hello! The umbrella tube is a stationary part, it does not rotate. The dirt that enters in the dirt cup spins around the umbrella tube. If no dirt is entering into the dirt cup this can mean there is a blockage either in your hoses and/or your filters. Try these quick trouble shooting steps below.
1. Remove the dirt cup canister from the vacuum. Twist off the dirt cup lid.
2. Remove the primary foam filter. Hold filter under running water until water runs clear. Allow 24 hours to air dry. If the filter is really dirty it may need to be replaced.
3. Slide the Hepa filter out. Tap the filter against the trash can until dirt stops falling. Replace the Hepa filter. (Do not wash)
4. Remove the hose from both ends. Use a broom stick to gently loosen and clear any clogs from hose.
5. Use a wooden spoon or something similar to loosen and remove any clogs from the lower hose. Hope this helps!
How do I get a dirt devil purpose for pet instruction manual?
Hello! We have several Purpose for Pets models. I have included the link to the Purpose For Pets Bagless Upright Vacuum model M140000 instruction manual. If this is not the model you have please reach back out to us and include the model number. Hope this helps!
http://bit.ly/1pB8DM1
Hoover wind tunnel the red light dirt finder stays on
There's a microphone inside the tube the dirt runs up. It listens for dirt coming up the tube. They just go bad and there's no making it better. You can either replace that entire assembly or ignore it. Fairly easy to replace. I'll include the part so you know what you're looking at.
Good luck! The Vac Dr.
http://vacuummedic.com/product.php?id=481
Red light stays on and never goes back to green....
This is a common problem with this model. There is a microphone in the rear duct that is not firmly seated. Usually this can be cured by removing the duct at the rear of the vacuum, that the hose attaches to, and using a small screwdriver to push around the outer edges of the small round microphone button. It may not look as if anything is happening, but this will usually cure the problem. I like to put a small piece of sponge or rubber against the mike to hold it more firmly in place prior to re-assembly.
Why doesn't the dirt sensor work? The read light stays on permanently. I have cleaned and checked everything.
2helpful
When vacuuming, dirt goes directly into canister not through filter help!!
The purpose of the filter is to prevent dirt from getting to the motor. The dirt is supposed to go into the canister.
M084600 Dynamite Bagless Upright Vacuum: loss of suction...
A few weeks ago I ran into the same problem, virtually no suction. First I replaced the bad belt (make sure you fit it right or it'll destroy the belt, luckily I bought 2!) and while the vacuum sounded more "alive" it didn't seem to pick up anything any better. The final solution was taking apart the entire intake port section down to the motor and getting the collection tube. It was filled with junk all the way up. I spent over an hour clearing out gunk and animal fur throughout the tubing. Putting it back together was a cinche because the entire vacuum uses one screw type universally. The whole process was pretty intuitive and its clear it's meant to be taken apart for just this purpose.
5helpful
Scooba not picking up dirt
I have had the same problem for six months and finally found the solution.
The problem is that the air duct into the dirty water tank was blocked. The air flows up the black removeable hose, into the dirty water tank and out through the filter. With the air duct into the dirty water tank blocked, no dirt gets anywhere near the filter.
The black removeable hose is the hose in the base of Scooba that the instructions tell the user to clean after each use. Despite cleaning this hose after each use, plenty of cat hair and other dirt passed by the hose and got lodged above it on the tank side of the incoming air duct.
The air duct into the dirty water tank is formed out of the blue plastic the tank is made from. You can find it by looking to see where the black removeable hose lines up with the tank when it is placed on Scooba. It is the same diameter is a the removeable black hose so you can't miss it.
Getting the gunk out is tricky because there is a bend in the duct. I fished most of it out with my fingers and then poked a bendable plastic spoon handle to get further down the duct. I then flushed water down it and shook the tank to get more out. After cleaning, water dripped into the air vent would come out the dirty water tank drain hole with little resistance.
After cleaning the air intake duct I ran my Scooba and got dirt in the filter for the first time in months.
29helpful
4answers
Dirt finder sensor stopped working
I had the same problem with a hoover windtunnel 6200 - u5477-900. I removed the flexible hose from top of the plastic tube running vertically along the right side of the back of the vacuum. When I used a flashlight to look into the plastic tube, I could see a clog at the bottom, where the flexible hose curved frontwards towards the brushes. I then removed the 2 screws holding the vertical plastic tube to the vacuum. When I disconnected the plastic tube from the flexible hose at the bottom, I found a clog of dirt and dog hair. After removing the clog and reassembling, the clean / dirty light now moves back and forth from red to green.
Hoover U5450900
On the back, take the hose off, inside the duct you can see a disc,(it is on the bottom of the duct) it may be filmed over with dirt, that is the sensor, clean it off then try again. If it still comes on, then it may be bad or you have a clog in the hose or the dirt inlet by the brush roll.
Top Hoover Vacuums Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
