Question about Nikon Coolpix 3200 Digital Camera
How do I Downloading from Rokinon dc59 - Nikon Coolpix 3200 Digital Camera
Manual for a rokinon for DZ880
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Rokinon Tripod t50 Quick Release Plate Missing...
You will have to contact manufacturer and give them your model t50 and go from there. Don't know if they supply part for their products.
1helpful
How to attach filters to a Rokinon 500mm/ 1000mm Mirror Lens for Canon EOS
For the Rokinon 500mm F/6.3 lens, you can either attach 95mm filters to the front or 34mm filters to the rear of the lens.
For the Rokinon 500mm F/8 lens, you can only attach 30.5mm filters to the rear of the lens.
To attach a filter to the rear of the lens, remove the lens from the camera (or take the rear lens cap off). There's a threaded screw mount just inside of where the lens fits onto the camera. Take your filter and screw it into place. Hand tighten until it's snug and doesn't project in the way---remember, you're going to want to take it off again later.
When I add a sandisk 4gb card to the camera it says card full. Is 4gb to big for a dc59?
A 4Gb card will be an SDHC card. SD and SDHC cards fit the same slots, but many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible.
ROKINON AUTO ZOOM Macro--- HELP to enable macro
Some of the Rokinon (and other ) zoom lenses could only go into MACRO at certain focal lengths- the lens you have "zooms" from 80 to 200 focal length,but is that done by "sliding" a ring forward and back on the lens, or by twisting a different ring that the one that focuses?
1helpful
Will the Rokinon 85mm 1.4 lens autofocus with the Nikon D90?
No!
The Rokinon is like the Nikon 85mm AIS lens and is manual focus only..
Hope this helps, Andrew
Can i download a guide for my power zoom DZ980 camera
I have spent over an hour searching for a manual. Since the manufacturer doesn't seem to have a website, I thought maybe one could be found on other help sites. I came up empty. I did find other users searching for manuals but they came up empty as well. Sorry I couldn't help.
What size of memory card and brand should I get for my new Rokinon E-Touch DZ1000
This camera has SDHC card expandable. With a minimum capacity of 4GB. So that means you can buy 4GB, 8GB ... whatever you budget.
Nikon Coolpix 3200 Digital Camera Logo
Top Nikon Cameras Experts
Ekse
Steven Wander
Steven Wander
Are you a Nikon Camera Expert? Answer questions, earn points and help others
