SOURCE: nikon coolpix 5700
at the back of the camera next to the view finder (bottom right hand corner) is a button and icon marked SEL. pressing this button toggles the lens image from the view finder to the lcd screen and back again. IF neither view is available then I suspect your camera needs some TLC at a repair shop. hope this helps.
SOURCE: Nikon coolpix 5700 shows no memory left after purchasing a new card & batteries
The largest CompactFlash card that Nikon approved for the 5700 is 256MB, which is what I'm using in my 5700. That's small by today's standards and you probably won't even find it in stores. I see some web sellers have 256MB cards for only $6 or so. Other commercial card sellers on the web claim that the 5700 will handle CF cards up to 1GB capacity. That's what I might try since online they're selling for as little as $8 plus shipping. Given that the 5700 was introduced in 2002, any cards bigger than 1GB probably won't work.
SOURCE: Trying out new 4G SanDisk cf memory drives in Nikon Coolpix 5700
There is a simpler solution. Just do this: 1. format the card in the camera 2. Connect it via card reader to your PC 3. Copy a little over 2Gb of data to the card - to a different folder 4. Put the card into the camera 5. It should work now... This way you can save some valuable data to the remaining 2 gigs of the card. Note: This has been tested on Nikon Coolpix 5400, but should work on 5700 as well
SOURCE: Sound problems with my Nikon Coolpix 4600 camera
Coolpix 4600 has no microphone, 5600 has one.
SOURCE: How do you record video with Nikon CoolPix 5700
There will be vedio mode in that.......select it and press recording button...
