Bosch Axxis WTL 5410 Electric Dryer Logo
A
Anonymous Posted on Apr 26, 2014
Install blower belt - Bosch Axxis WTL 5410 Electric Dryer
2answers
How can I hook up the snowblower attachment?
if its a garden tractor then you will first need to remove the mowing deck , this is easy if you have something to run front wheels up on to allow you room to pull deck out the side ,set deck height all the way down, save the drive belt . save the deck pins . locate the front chassis mounting arms and drive up to blower allow rear mounting arms to go between the two front wheels till the back of blower meets the front of chassis mounting arms (tight fit) install pins at all four points of contact , install belt to blower and front pto of machine (install any guards for belt) then raise blower from ground with deck height adjustment lever (it might feel heavier) test it to prove good contact your done
if its a three point (this is the reason I own one know) you back up to blower lower the mounting arms , engage the quick pins , install the drive shaft between the blower and machine with a quick spring snap , connect top link to tractor get back in seat and start machine raise three point an go !!
Jan 19, 2016 • Garden
What has to be disasembled in order for me to install new belts on my 27" blower
YOU CAN GO TO GOOLGE AND TYPE IN THE QUESTION , YOU TUBE WILL HELP YOU WITH THIS IT WILL SHOW YOU HOW TO CHANGE THE BELT AND THE BRAE DOWN ON HOW TO DO THIS
Feb 22, 2015 • Garden
Change belt on snapper 722 snow blower
1. Remove the belt cover with a socket wrench. Slide the belt cover off and set it aside.
2. Remove the two belt cover stud bolts with a socket wrench to get to the auger belt guide. 3. Remove the belt guide with a socket wrench.
4. Push down on the belt tensioner pulley with your hand. Remove the old belt and set it aside.
5. Install the new belt and release the belt tensioner pulley to tighten the belt.
6. Re-install the belt guide with a socket wrench and tighten the bolt.
7. Re-install the two belt cover stud bolts and tighten with a socket wrench.
8. Re-install the belt cover and secure it with the cover bolts. Tighten the bolts with a socket wrench.
I pulled the following from a snaper model similar to yours.
The snowthrower has two drive belts, one for the traction
drive-which transmits engine power to the wheels, and
a second for the auger drive-which transmits engine
power to the auger mechanism.
Each of these drive belts are of special construction and
should be replaced only with genuine replacement belts
which match the original equipment belts. These are
available from your dealer.
Traction Drive Belt Replacement
I pulled the following from a snapper model similar to yours. Believe it should help.
1. Disconnect spark plug wire and fasten it away from
the spark plug.
2. Remove belt cover. (Located in back of the discharge shute).
3. Pull the traction drive belt idler pulley arm (See
Figure 24) away from the belt to relieve tension, and
slide the belt off the engine pulley.
4. Slip the belt off from around the traction pulley (See
Figure 29) and pull the belt out of the unit between
the auger pulley and the traction pulley (the lower
cover need not be removed for this step).
5. Reverse the procedure to install the new belt. Be
sure there are no twists in the belt, and that the belt is
properly seated in the pulley grooves.
6. Replace the belt cover.
7. Start the unit, and check the traction drive for proper
operation. See "Traction Clutch Cable Adjustment"
for adjustment procedures.
There are also several videos on YouTube on changing snowthrowr belts. (Didn't see one for your blower, but most similar and should provide a good starting reference).
Snowblower attatchment not working
you must get a longer belt and, install an idler pulley
your craftsman dealer has the conversion kit parts
Nov 18, 2013 • Garden
2answers
Honda pilot 2007 blower fan making noise blower fan was replaced once still making noise
Either its developed the same fault or the fan motor bearing has failed, needs greasing or, if there's a belt, the belt is slipping.
How to replace rear blower motor motor in 2006 chrysler town and country van
from autozone.com:
Removal & Installation
  1. Disconnect and isolate the negative battery cable.
  2. Remove the right quarter trim panel as follows:
    1. Remove first rear seat. Remove the second rear seat, if equipped.
    2. Remove the sliding door sill plate.
    3. Remove the quarter trim bolster.
    4. Remove the upper C-pillar trim and D-pillar trim panel.
    5. Remove the first and second rear seat belt anchors.
    6. Remove the screws securing the quarter trim to quarter panel from the bolster area.
    7. Remove the screws securing the rear edge of the quarter trim to the support bracket.
    8. Carefully disengage the hidden clips securing the front of the quarter trim to the quarter panel just rearward of the sliding door opening.
Fig. Removing the trim panel to access the rear blower motor
i. Disconnect the wiring harness connector from the accessory power outlet, if equipped.
j. On long wheelbase wagons only, remove the quarter trim from the quarter panel and pull second rear seat belt through access hole.
k. Pull first rear seat belt through the access hole.
l. Remove the quarter trim panel from the vehicle.
3. Remove the 5 screws mounting the A/C-heater blower motor housing to the rear HVAC unit (one mounting screw located on evaporator cover).
4. Twist the blower motor out of scroll housing.
5. Disconnect the blower motor wiring connector.
6. Remove the blower motor from vehicle.
Fig. The rear blower motor is held in place by four screws
To install:
  1. Install the blower motor unit into the vehicle.
  2. Reconnect the blower motor wiring connector.
  3. Secure the blower motor into scroll housing.
  4. Install and tighten the 5 screws mounting the A/C-heater blower motor housing to the rear HVAC unit (one mounting screw located on evaporator cover).
  5. Install the right quarter trim panel as follows:
    1. Install the quarter trim panel in position in the vehicle.
    2. Insert and pull the first rear seat belt through the access hole in quarter trim panel.
    3. On long wheelbase wagons only, insert and pull the second rear seat belt through access hole in quarter trim panel.
    4. Reconnect the wiring harness connector to the accessory power outlet, if equipped.
    5. Engage the hidden clips to secure the front of quarter trim to quarter panel rearward of sliding door opening.
    6. Install the retaining screws that secure the rear edge of quarter trim to support bracket.
    7. Install the retaining screws that secure the quarter trim to the quarter panel in bolster area.
    8. Install the second rear seat belt anchor (if equipped), and the first rear seat belt anchor.
    9. Install the D-pillar trim panel and upper C-pillar trim.
    10. Install the quarter trim bolster.
    11. Install the sliding door sill plate.
    12. Install the second rear seat, if equipped, and install the first rear seat.
  6. Reconnect the negative battery cable. Check blower motor operation.
How to replace the blower motor in a dodge 2001 caravan
    9. Disconnect the wiring harness connector from the accessory power outlet, if equipped.
    10. On long wheelbase wagons only, remove the quarter trim from the quarter panel and pull second rear seat belt through access hole.
    11. Pull first rear seat belt through the access hole.
    12. Remove the quarter trim panel from the vehicle.
To install:
Hope helps (remember to rate this).
How do I replace the fan blower?
GM Celebrity/Century/Ciera/6000 1982-1996 Repair Guide
Blower Motor - REMOVAL & INSTALLATION
This procedure is applicable for vehicles, with or without air conditioning.
  1. Disconnect the negative cable at the battery.
  2. On the 3.1L (VIN M) you will need to remove the serpentine belt and move the alternator aside.
  3. For the 2.2L (VIN 4), disconnect the air inlet resonator, then remove the torque strut from the engine. Rotate the engine slightly forward.
  4. Working inside the engine compartment, disconnect the blower motor electrical leads.
  5. Remove the motor retaining bolts. If there is a hose disconnect it, then remove the blower motor.
To install:
  1. Position the blower motor on it's mount.
  2. Install the mounting bolts and tighten until snug.
  3. Attach the drain hose if removed, then engage the electrical connection to the motor.
  4. On the 2.2L (VIN 4), properly position the engine and install the torque strut to the engine. Connect the air inlet resonator.
  5. On the 3.1L (VIN M), install the alternator, if removed. Install the serpentine belt.
  6. Connect the negative battery cable, tighten the cable bolt to 11 ft. lbs. (15 Nm).
  7. Reset the radio, clock and any other applicable electronic devices.
Hope helps (remember comment this)
1helpful
Where is the blower motor resistor in a 2001 dodge caravan se. I do not see it behind the glove box. I do see soemthing similar under the hood on the passenger side aginst the firewall but it is not...
Caravan, Grand Voyager, Town and Country, Voyager, 2000-2004
Blower Motor - Removal & Installation
  1. Disconnect and isolate the negative battery cable, then wait 2 minutes before proceeding with the removal. This will effectively disable the air bag system preventing possible personal injury.
  2. Remove the glove box from the instrument panel.
    Fig. The blower motor is located behind the glovebox, behind the blower motor cover
  3. Remove the A/C-heater blower motor cover.
  4. Disconnect the blower motor wiring connector.
  5. Remove the blower motor wiring grommet and feed the wiring through the blower motor housing.
  6. Remove the blower motor mounting screws.
    Fig. Once the cover is removed, unplug the electrical connector and push it through the opening in the housing
    Fig. The blower motor is secured to the housing with three small screws
  7. Allow the blower motor assembly to drop downward to clear the instrument panel and remove from vehicle.
To install:
  1. Place the blower motor assembly into position on the A/C-heater unit and tighten the mounting screws.
  2. Route the blower motor wiring through the blower motor housing and seat the wiring grommet in the hole of the blower motor housing.
  3. Reconnect the blower motor electrical connector.
  4. Install the A/C-heater blower motor cover.
  5. Install the glove box into the instrument panel.
Auxiliary Heater and Air Conditioner
To install:
Hope helps (remember rated this).
Installing drum belt on dryer trouble accessing pulley b/c blower
Hi, There are many different models/makes. Get me the model # and I can help you with this.
Vic
Jul 15, 2009 • Dryers
Top Bosch Dryers Experts
vince
NOEL
NOEL
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
