Just for 1993 ford thunderbird lx 3.8 li, NOT super charged. I preformed paper clip diagnostic engine light flash test & these are the number of flashes I received 116327 then again 116327 please help! Thank you so much.
I found a couple of codes that may be the cause here is the first one and the seond right under it thay seem to point to the EGR or EVR valve pressure issues it might need replacing. this is the 327 code can't find more than 3 digits for a Ford error code
Electronic pressure transducer (EPT)/differential pressure feedback exhaust (DPFE) sensor/electronic vacuum regulator (EVR)
327
(O,R,M)
EGR feedback signal is/was low - EVR or PFE
you might be getting 2 three digit error codes as Ford only has 2 and 3 digit codes form all the sites I've checked. a 116 code is this
Out of range Engine coolant temperature sensor (ECT)
I hope this helps some
