Question about Light Outboard Motor Boat Bass Fishing Saltwater Base
What is the gas oil mixture for 1980 johnson 15hp
charles coates
    New Friend:
  • 4 Answers
50 to 1 ratio 16 ounces of oil for 6 gal of gas
Posted on Apr 27, 2014
I have a 1980’s 2 hp Evinrude out board motor. What oil/gas mixture is. Recommended?
Depends on the type of oil you choose, there are several different oils 20:1, 40:1, 50:1, due to the age I would start with 20:1 oil, the worst that could happen is it would run with an oil rich mixture, be sure and use lead free gasoline if possible. all of the oils will work, but due to the mixture it affects the amount of gasoline going through the carburetor jet. More oil less gas, less oil more gas.
Mar 27, 2018 | HP Garden
Oil gas ratio 86 15hp johnson
Should state on motor plate. Normally 50:1
Mar 15, 2018 | Boating
Oil gas ratio for 86 15hp johnson
The ratio mix is 8oz.two cycle oil to one gallon of gas.
Mar 15, 2018 | Garden
Oil-gas mixture for a 1975 15hp johnson
24:1 should be fine.. if you start fouling spark plugs.go to 28:1..
USE A QUALITY TWO CYCLE OIL - Certified TCW-3...
...I would rather foul a spark plug than replace a piston!!!!
16:1 24:1 32:1 40:1 50:1 US Gal US ounces of oil 1 8.0 5.5 4.0 3.2 2.5 2 16.0 10.5 8.0 6.5 5.0 3 24.0 16.0 12.0 9.5 7.5 4 32.0 21.5 16.0 13.0 10.0 5 40.0 26.5 20.0 16.0 13.0 16:1 24:1 32:1 40:1 50:1 Litres US ounces of oil 5 10.5 7.0 5.5 4.0 3.5 10 21.0 14.0 10.5 8.5 7.0 15 32.0 21.0 16.0 12.5 10.0 20 42.5 28.0 21.0 17.0 13.5 25 53.0 35.0 26.5 21.0 17.0
Sep 24, 2017 | Garden
Does 1984 25hp johnson at tor need 2cy oil mixed wiyht gas
All 2stroke engines need 2stroke oil in the fuel !!! 50 to 1 mixture ! fuel to oil !...
Sep 23, 2014 | Seloc Johnson Outboards 2002-2007 Repair...
Evinrude outboards
Johnson and Evinrude carbureted 2-stroke outboards since 1964 require a 50:1 fuel to oil mixture (2%) on engines without an automatic oiling system - 6 gallons of gas to 1 pint of outboard oil.
Aug 30, 2014 | Garden
Do i need to mix fuel for a 1988 15hp johnson outboard motor J15RCCS?
Yes.Fuel mix is needed.Mixture is 50/1 fuel /oil. Eg.50 litres of fuel/1 litre of oil.Oil bottles you buy have measurements on the side of them.Hope this helps
Aug 29, 2009 | Boating
Motor was running great, but it died slowly and never start again
check to see if you have a spark -then check if you are still getting fuel-and how old is the fuel-because it is recommended ,an im assuming its a 2 stroke motor,that the fuel should be replace with a fresh 2 stroke mixture every couple of months as the mixture jellyfies and sludges up the carb etc-try those first
Jul 06, 2009 | Sport & Outdoor - Others
Light Outboard Motor Boat Bass Fishing Saltwater  Base Logo
203 people viewed this question
Top Light Boating Experts
ray gallant
Andrew Taylor
Andrew Taylor
jws1013
Are you a Light Boating Expert? Answer questions, earn points and help others
