The upper oven fan does not come on in baking mode
SOURCE: Double oven / convection not working
It is likely that the convection element is burned out and needs to be replaced. If all other functions are working then this is the place to start. Teh back panel inside of the oven can be removed by removing the 4 visible philips screws on it. The element should look smooth and round, if not then it needs to be replaced. Be sure to turn power off to the oven before replacing it. Remove the screws that fasten the element to the back wall and gently pull the element away from the wall an inch or so. the wires will be exposed and can be unclipped from the element do not let them fall inside of the back of the oven or you will have to remove the oven from the wall to get at the back panel. Install the new element in the reverse procedure. If the element looks good then it will have to be tested with a multimeter to verify that it is still good before proceeding to check the selector switch for burn marks.
SOURCE: bosch oven
looks as though youre circotherm element has blown (open circuit) you will need to remove oven and check with multimeter should read around 35-37 ohms on 2.5 kilowatt heater if open circuit will need replacing easy to do on most ovens and no too expensive around £30-£35 for element depends on model and output power.
hope this helps
SOURCE: I have a Bosch HBN 455 double oven with the
All the controls are on the top. Using self clean excessively causes damage to electronic circuits.I do no advise the usage of self clean especially for something as complex and expensive as this bad bot. I have the repair manual for this oven. I am trying to get it to download where I can send it to you. It is 55 megs. I need you to comment back so I can have a way to link it to you when I get it loaded to Gdocs. Dang computers. Wish I had a faster one but I fix stoves not pcs. LOL Whats gonna happen is My 30 minutes is gonna be up before I can get you the document. Waiting for your reply.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: My HBL452 double oven is slow to heat both upper
If your electric oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
SOURCE: upper and lower elements in my bosch HBE 632 elec
Hi.
If it is a fan assisted oven, and it is the fan oven you are referring to, then I would suspect the fan element to be faulty.
Assuming you are in the U/K, this should be located at the rear of the oven compartment behind a removeable cover.
Alternatively, it is possible that the selector switch could be faulty, but I would check all elements first.
