I suggest you study the instruction manual and maybe contact the manufacturer in case there is a reset method.
It shouldn't be overlooked that a power outage is often accompanied by a power surge or a voltage transient or spike capable of damaging sensitive electronics, in other words computers!
Almost everything is a computer these days, which is why every home should have major appliances provided with surge protection and some area protection. Half a dozen surge protectors around the home protecting major appliances will provide a degree of "herd" protection to some of those items without direct protection.
SOURCE: maytag,electric stove-
you need to order a custom control kit, electronic switch that contorls onlly that one burner
SOURCE: the on indicator light stay on all the time on Maytag touch 500
you have a bad switch, you need to unplug the wire going to the conector marked P on one switch at a time til you find witch switch is bad. if you have turned off the breaker to it and the light is still on then the power is not off to it there is not a batery in it, careful that glass breaks easy when out of it's can
