Question about Hayward Pool & Spa
1-1/2HP Drivetrain Upgrade Kit how to assemble?
Need instruction to install drivetrain upgrade kit for Hayward SPX2610C KIT
5 Related Answers
Anonymous
  • 29 Answers
SOURCE: Haier Upgrade Kit
In one of my earlier post I posted the phone number where to order the board. However they were on back order so I got lucky an located the upgrade kit on Ebay. I'll post the part number for the kit and boards you need. TV-3940-01 is a kit that contains the following parts:
Control Board – TV-5210-39
Y-Sus – TV-5210-35
Z-Sus – TV-5210-37
EEprom (2006 version) - TV-2455-03
Posted on Apr 20, 2008
Anonymous
  • 417 Answers
SOURCE: magellan roadmate 800 update maps
http://www.peopleswireless.biz/magellan-rm800-traffic-kit.html
No You Will Need A traffic kit
Posted on Jul 05, 2008
Anonymous
SOURCE: info on TV-3940-01 kit for haier
i have the haier upgrade kit. originally sears was to repair my 42ep24s but the kit was in back order and after a long wait and several phone calls, sears decided to replace my tv. two weeks later, the kit arrived infront of my door. now i have a new tv and an upgrade kit. email me if interested. [email protected]
Posted on Jul 26, 2008
Anonymous
  • 26 Answers
SOURCE: TV-3940-01 Upgrade Kit
Yes. Make sure you follow the instructions that came with the kit.
By the way - where did you get kit? I am trying to find one. I even contacted HAIER China.
Posted on Nov 16, 2008
Anonymous
  • 11 Answers
SOURCE: Removal and installation of diffuser and impeller kit
All jucuzzi pumps are some of the most difficult to repair.Pump front should seperate from body(volute) of pump by means of screws, or some kind of band. Diffuser should have ss screws, or
be held in plsce by notches or both. Impellor spins counter clockwise to come off. Can only remove impellor with impellor wrench, or very strong hand. Rear of motor must be held in place with normally a 7-16 wrench, allen head wrench or screwdriver. Depends on manufacturer of motor. Then impellor can be removed!
Should replace shaft seal under impellor. Can seperate body of pump from motor by turning four outer bolts on back of motor. Must mark rear cover of motor so lines up exact for reassebly. Ussually 1/4 inch socket wrench.Seal can be pushed out from back to front with the corrrect size socket and a very light hammer.
Try to factory Jacuzzi seal, they are better than aftermarket.
Coat rubber on seal with light silicone, and press back into place without touching or marring seal face. Best way is use other half of seal (spring piece) to gently but firmly reseat seal. Examine body from rear to make sure seal seats. Reassemble as taken apart, or just take to a qualified service tech at a well established pool/spa place. Kirk
Posted on Feb 17, 2009
Are cv boots replaceable
CV boots are replaceable,but most times it's just as cheap to replace the complete axle.
Jul 10, 2017 | Cars & Trucks
Magellan roadmate 800 update maps
Jul 05, 2008 | Magellan RoadMate 800 GPS Receiver
Where to purchase upgrade kit for Bernina 200?
This part can be installed ONLY by an authorized BERNINA service! Every BERNINA technician can order it.
artista 200/730 Upgrade Kit 032049.71.00
Feb 27, 2013 | Bernina artista 200
I have a Mackie D8b hooked up to an HDR 24/96.... Everything works except the Jog Wheel and the locator buttons on the console... They just flash when you press play.and will not communicate with the cpu....
Do I need to upgrade my Mackie or Logic Control?
A.
Perhaps, but perhaps not. Really, it all boils down to what you are doing or plan to do with your Mackie Control or Logic Control. First, determine the Firmware Version of each of your units (main units AND extenders) - simply watch the display when you power up.
If you have a version 1.x Mackie or Logic Control (including extenders), there is a free MIDI download which will allow you to control all of the Mackie Control supporting DAWs AND Emagic Logic Audio.
If you have a version 1.x Mackie or Logic Control (including extenders) and wish to control Pro Tools via Mackie Control Universal's built-in HUI mode - you'll need to obtain a Mackie Control Universal Upgrade Kit.
If you have a version 2.0 Mackie Control or extender, we have a free MIDI download which will allow you to control all of the Mackie Control supporting DAWs, Emagic Logic Audio and Pro Tools.
If you have version 2.1.1 - you're already up to date.
Free for all existing Mackie Control, Logic Control, and MC or LC Extender owners, this download will update your control surface to have both Mackie Control and Emagic Logic Audio functionality. HUI support for Pro Tools is not included in this download. Instructions for updating your unit(s) are included as a Read Me file in the downloadable zip archive. 1. If you own a Mackie Control or XT with firmware version 1.x and you want to add Logic Control Functionality, download this free MIDI upgrade.
Mackie Control v1.2 (ZIP 13KB)
This upgrade is for those Mackie Control, Logic Control, and MC or LC Extender owners who want to update their control surface to the full three-mode Mackie Control Universal - getting HUI mode for Pro Tools along with the Mackie Control and Logic Control modes. 1. If you own a Mackie Control with firmware version 2.x and you want get all three modes: Logic Control Functionality, Mackie Control Functionality, and HUI Mode for controlling Pro Tools, download this free MIDI upgrade. Instructions for updating your unit(s) are included as a PDF file in the downloadable zip archive.
Mackie Control Universal v2.1.2 (ZIP 21 KB)
Note: the 2.1.2 firmware upgrade is new as of August 20, 2004.
  • Fixes Bug in Logic Control mode that caused lock-out of control surface on termination of software application
How do I upgrade my Mackie Control, Logic Control or Extender?
A. First, make sure that you DO need to upgrade (refer to the previous FAQ). Once you've determined that you need to upgrade your unit, you'll need to reserve an upgrade kit. Reserve your kit here.
Because there is limited supply of the upgrade kits, we are taking reservations. Once your upgrade kit becomes available, we will send you an email with instructions on how to obtain your kit. You will have 72 hours to respond before we release your kit to the next person in line.
The Mackie Control Universal Upgrade Kit includes a new processor chip, a Pro Tools Lexan overlay and installation instructions. You can either perform the upgrade yourself, or have a professional from the Mackie Service department perform the upgrade for you. You can also choose to have a third-party service technician perform the upgrade for you at your own risk.
Dec 12, 2010 | Computers & Internet
When I try and connect the HP wireless upgrade printing kit it doesn't recognise the adapter and so won't procede. Any ideas?
you do not need an upgrade kit.....this printer is a wireless printer.....so can use it wirelessly without any upgrade kits.....just need to run the wireless setup wi\zard on the printer from the front panel menus and then nyou have to install the s/w using the disc that came along with the printer and you need to select the connctivity as wireless and then follow the on screen instructions...
Mar 27, 2009 | HP Photosmart C7280 Printer
Hayward Navigator Pool Cleaner Will Not Move
The problem is that you have too much play in your drivetrain. You will need to check for movement between the pod and the a-arm and then between the a-arm and turbine. It would also be a good idea to check the turbine bearings. Find the loose fitting, worn part and that is your problem. As far as it not twisting on the end of the hose; this is most likely caused by the screen on the back of the unit being obstructed by debris or the gearbox assembly being jammed by debris that got through the screen or is just worn out. If you have any mechanical abilty you shoud be able to do these repairs yourself with the help of a downloadabe exploded diagram. If not call a pool repairman the parts are not really that expensive compared to the cost of a new unit.
Jan 28, 2009 | Hayward Navigator Pool Cleaner
Upgrade kit part: TV-3940-01 - But the part is backordered for three months. $150.00
I beleive this comes directly from manufacturer.becasue thsi Kit cotains a upgraed E-prom.
before you order any kit check it this unit has been upgraded before? if this unit upgraded before you dont need to change kit again.
I would say either y-sus or z-sus could be the problem..
Good luck
Dals123
Sep 30, 2008 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
Info on TV-3940-01 kit for haier
Sorry, the Haier Upgrade Kit is SOLD. My original post is months old and the kit sold right away. Good luck to you on locating another one.
Jul 14, 2008 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
Adding second CPU
Hi
Did you receive a VRM with the the PRC upgrade kit? And have you installed it?
The following items are/should be included in a microprocessor upgrade kit:
• A microprocessor (PRC)
• A heat sink
• Heat-sink retention clip(s)
• A voltage regulator module (VRM),
Your upgrade kit may also include a cooling fan.
If you are adding a secondary microprocessor, examine the VRM to ensure that it is the correct VRM for your system. Install the VRM in the appropriate secondary VRM connector, ensuring that the latches at each end of the connector engage. If you received two VRMs with the upgrade kit, replace the primary VRM already installed in the system with one of the VRMs from the upgrade kit.
Note: The system does not support mismatched VRMs.
Check PE1600sc Microprocessor Upgrade Installation Guide - http://support.dell.com/support/edocs/systems/pe1600sc/multlang/proc/9D904A05.pdf
Let me know how you get on
Mike
May 13, 2008 | Dell PowerEdge 1600SC Server
Pool & Spa Logo
23 people viewed this question
Top Hayward Pool & Spa Experts
john h
Marvin
Marvin
Paul Carew
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
