Question about Sharp MX-2700N Color Copier
Turn on hole punch canon ir5065 - Sharp MX-2700N Color Copier
Canon ir5065 error E000400-00100 details
it is assumed that some spare parts are replaced designed for other country. ID MISMATCH BETWEEN DC CON AND LSU.
Thanks.
Dec 20, 2014 | Office Equipment & Supplies
Canon ir5065 Error detailsEooo4-oo400
sir
clr the error code in service mode. then check the the heater power supply (may be country mismatch). check the dc-con pcb.
thanks.
Canon hole punch
Go into the printer options settings on the PC and make sure the "punch" is enabled. Especially on Windows PCs, it's common that not all the options are communicated between a network printer and the computer.
Apr 25, 2014 | Canon imageRUNNER 7200 Copier
Swingline 74030 manual hole punch handle is locked down
by locked down I am going to assume you mean it will not go back to the normal postion when it is not making a hole. this can be caused by too many of the scrap pieces of paper that are left from making the hole. clogging the punch area. remove all the excess pieces of paper that may be stuck in the whole punch, then try again, you may have to pry the handle and or push and pull it until it releases. do not use again until the handle moves smoothly, clean the areas around the punch.
Mar 07, 2014 | Swingline 74030 Manual Hole Punch SWI74030
My hole punch won't release the paper. I have to jiggle it before it finally releases.
You are stacking too many sheets of paper. Reduce the thickness of the stack. Think of all the time wasted while trying to the paper released. Sometimes the holes punched may be ripped.
Aug 22, 2013 | Sparco High Volume Electric Three-Hole...
Canon ir5065 eror000808-0002
This error is caused due to faulty thermister however; you can check the fuser unit for any jammed paper around the upper fixing roller and try to clean that area. After this is done try to clear the error by entering the service mode, to enter press Additional functions, #. Then go to #7 Printer and press OK, then go to #4 printer reset and press OK, yes= *. If the issue returns then replace the thermistor. Hope this helps...please post back for further assistance.
Aug 07, 2012 | Canon iR 5065 All-In-One Printer
Eroor e000423-0002
Search online for "error code e423 canon ir5065". Get plenty of hits - best one looks to be 'copytechnet. com'
Mar 02, 2012 | Office Equipment & Supplies
How to remove hole punch waste
yep just open the front door of your finisher then you will see some drawings/pictures on 'how to' for removing punch waste.
Mar 23, 2010 | Canon imageRUNNER C5800 Copier
Sharp MX-2700N Color Copier Logo
27 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
