The lcd screen on my eos 350d won't display there are lines across the screen
SOURCE: lines across images
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Posted on Mar 18, 2008
SOURCE: Error 99
Error 99 is an "unspecified" error. It can sometimes be due to poor communication between the lens and camera. Here are some things to try:
1) Turn the camera off. Remove the memory card. Remove the lens. Replace the lens. Turn the camera on. Replace the memory card.
2) If that doesn't fix the problem, try cleaning the contacts on the lens and camera. Turn the camera off and remove the lens. Hold the lens upside down (contacts down) and gently rub the contacts with a clean pencil eraser. Be very careful to ensure that the eraser debris falls on the table and not into the lens. Repeat with the camera body, also holding it upside down (contacts down) as you clean. Replace the lens.
If neither of these work, then you need to send the camera in to Canon for repair.
Posted on Dec 26, 2008
SOURCE: New EOS XSi LCD don't work
You have to set the camera to "Live View" mode. Check your manual for settings.
BTW, it's usually a bad idea to use Live View mode unless the camera is on a tripod. With Live View you have to hold the camera out in front of you and it's much less steady.
Posted on Mar 19, 2009
SOURCE: Canon EOS 350D CF memory card won't go into slot
It sounds like you have some bent pins in the card slot. Take it to a reputable camera repair and they can look and tell you for sure.
Posted on May 12, 2009
SOURCE: Error 5 on Canon eos 350D
Well first of all you can try a full reset, Pull both batteries out -the normal one, and the date/time one. If your camera is older (>2 yrs), it may be time to replace that battery..... anyway Put a new one in, and then put in the freshly-charged main battery, that might clear the error. If further you have the same problem then something is causing the flash to stick. Press the button and pull gently on the flash. Post comments for more help or information needed.....
Good Luck!!
Thanks for using FixYa!!
Posted on Jul 07, 2010
