Televison & Video Logo
Posted on Apr 25, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hello my 32' alba tv (LCD32880H DF) wont turn on. Instead of the standby light being lit as normal it is flashing blue constantly
Level 3:
Top Expert:
  • Televison & ... Master 76,851 Answers
  • Posted on Apr 26, 2014
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14986618
Points
237762
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
More to say, continious blink of standby light denotes main board fault.
1 Related Answer
Anonymous
  • Posted on Oct 15, 2012
SOURCE: Hello my 32' alba tv
hw can i fix my alba 32880 hdf tv main ac
2helpful
2answers
My Nordmende television blue light below screen continually flashing & no tv screen.
Question edited for clarity, your television is 'Nordmende', not 'Norfmende'.
Time for a new one, but try the power reset first as mentioned here.
The standby light on my nordmende tv keeps flashing
JustAnswer https://www.justanswer.com > TV Problems
Sep 27, 2012 - Unfortunately, the symptoms you are experiencing (flashing power/status light, tv won't power on) are generally symptomatic of an internal ...
1 answer · Top answer: p0llinate : Hello, and welcome to justanswer, a pay site for expert technical help. My ...
How to fix my nordmende tv as blue light is flashing and ...
Ask Me Fast https://www.askmefast.com > How_to_fix_my_nordm...
Its the power supply board, capacitor(s) have gone. Solder on new or replace board. source: 26" lowry tv red and blue standby light flashing and tv wont turn on?
1helpful
Hello my 32' alba tv LCD32880H DF wont turn on. Instead of the standby light being lit as normal it is flashing
bad caps on power board.......
either repair caps or replace the board......
cheers
Alba 32 inch tv when i turn it on the off/on light keeps flashing but the tv wont go on
check for a power supply failure, replaced capacitors with leak and bulged on its tops. that cause the dc output supply to drop.
My Samsung LE32N7 does not come on. The blue light under the screen constantly flashes without the tv coming on.
Hi, maybe the TV controller board is blocked, you can reset it, by disconnecting power cable from outlet for about 5 minutes, if that doesn't work, possibly and internal board or component must be repaired of replaced, in such case it's better to contact an authorized Samsung service center or technician to check your TV.
6helpful
3answers
Alba 42"lcd tv watching tv it just went off,
Alba is now a product of Argos, their low cost help line number is 08456040105
TV turns on for a split second then back to standyby
i think your capacitor is blown, do a google search for insignia, lcd, capacitor...
you can buy another one for about $2 but its a pain to install, you can also instead buy a new powerboard for about $80, its an east install and you wont blow more capacitors
bestbuy.partssearch.com
Akai LCD TV wont turn on
Hello davidshu,
The issue seems to be a power supply problem. The television has a switching power supply. This might be the problem. I would suggest getting it repaired at a television repair shop due to the possible complexity of the work that needs to be done.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
