Im showing mine is made in Germany. . there're two model numbers AEG type E EM 0014 E613 578 986. Then Mod. ESF 200W 115v 50 HZ. need new blade for a very older model showing made in Germany 13 578 986 Appreciate some assistance
SOURCE: I have a Phoenix AEG juicer with no instruction
I have an old Phoenix AEG juicer - don't know if it's the same as yours. My basket is two-part. The flat bottom part with the grinder teeth holds in the strainer part, and has small holes at twelve o'clock and six o'clock. There is a clear plastic "wrench" which consists of a circular plate with a perpendicular ridge on top serving as a handle, and two pins on the bottom that fit in the two holes. You then unscrew the flat bottom part of the basket which releases the remaining strainer basket part. If you're missing the wrench you might be able to improvise.
