I have a 2002 cadillac deville, it will play store bought cd, but will not play burned cd. Any suggestions??? I have burned cd in mp3 and wma format, and will not work
SOURCE: CD Player wont play burned CDs
you need to make sure you burn your cd,s in the right format, mp3 i think
SOURCE: 98 cadillac deville battery wont hold a charge
sounds like a 12V drain on the system, like a trunk or glove box light that won't shut off.> Could be many. many other reasons why. The way I would find the draining circuit would be to remove the neg cable of the battery. I then would connect a 12V test light between the neg battery TERMINAL and the neg battery CABLE. With a 12V drain the light will shine. I would install into the light a 9V battery powered recepticle to hold computer and radio station memory. Then I remove fuses 1 at a time, then reinstall, at the same time looking for the 12V light to go out. Hope this helps.
SOURCE: 2002 Cadillac Deville steering wheel started
check your inner cv joints, I bet there's grease being thrown evrywhere! Is the smell a greasy burn smell 9 out of 10 you need new cv axles
