Question about Rowenta Vacuums
Take apart Delta Force suction head
Brush on bottom of power head will not turn. Need to get bottom plate off to access brush.
5 Related Answers
Anonymous
SOURCE: rotating brush will not turn on my Dyson DC07
Yes I had the same problem on my animal Dysom. There is a button on the top of the dysom that turns the cacuum on. Right beside that button is another one that turns on and off the brush!!! Good luck!!! I accidently one day bumped that button and couldn't get my brush to work but after troubleshooting it, that was my solution.
Posted on Jan 24, 2009
SOURCE: brush wont spin
Sound like it has a bad belt . I would check it and replace if bad .
Posted on Feb 23, 2009
Gabe Gilsrud
  • 98 Answers
SOURCE: dc11 dyson
I have taken the brush heads off and pulled all the hair out of the small gap between the chrome shaft and the plastic gear housing. Then a small amount of 3-in-1 oil into that gap to lube the internals and just a little through the air intake on the side of the head to clean and lube the seals and it works like new. This lasts about 9 months under high use and the process takes roughly 10 minutes.
Posted on Mar 23, 2009
drallim
  • 4088 Answers
SOURCE: brush spin,good suction at hose, no suction at
Air passage from back of brush head, through the joint, and up to bag, may be blocked.
Posted on Jul 12, 2009
Anonymous
SOURCE: motorized brush bar not turning on Dyson Vacuum
Apparent common failure is that either the thin yellow and or blue motor drive wires that run from the LH side of the vacuum where the "control board" is located down into the hinge / ball area become stretched and then fray and eventually break. Happened to my Dyson twice. First repaired under warranty, second took about 20 minutes. You need a Torx screwdriver to remove the LH panel ( 4 screws) and also an access panel (2 screws) at the side of the ball which permits access to the blue / yellow wire connectors. I replaced with a new wire and connectors having fed the wires through the access hole making sure sure enough wire was available for the movement of the handle. Also ensure that when the covers are replaced they do not trap any wires underneath.
Posted on Oct 04, 2009
The turbo tool for pet hair on my Hoover power vac doesn't rotate. I removed the brush and cleaned but still doesn't work. Suction is fine without the tool attached.
Have you checked the drive belt on the pet head? Mine comes apart and a thin belt is driven by the propellers which in turn drive the brush head via the drive belt. To check turn propeller and see if brush head rotates if not belt missing broken / jammed
Oct 21, 2017 | Hoover Vacuums
Replace brush head cover
Three slotted plastic fasteners hold the bottom plate in place. Turn. Them all to remove the bottom plate to gain access to the brush roll.
Aug 01, 2014 | Dyson DC07 Bagless Upright Cyclonic Vacuum
I fitted a new belt. Green light is on so brush is spinning. As I lower the head the brush slows to a stop as it contacts carpet.
There are much quality differences in belts but the foot pedal with arrow is made to set the hightbecarefully because of easy broken pedals . but if the brush is setting on the deepest stand then its not rotating anymore and the brush stands still. its very easy how you can disassemble the brush and can place them in 3 differend levels in height ? on the grey bearing holders outside of the brush there are 3 different indications l and ll and lll the best is to set so that the carpet if its a thin one the brush must setting just lower then the suction mouth so that the brush are more coming out so deeper come out of this suction mouth so that the suction mouth has made a little more distance from the carpet because when the brush rotate to deep insite the suction mouth .1 the tension of the belt on the brush is lower and .2 the suction mouth sucks vaccuum on the carpet and the brush doesnt rotate because of the force of suction power, play around with the different heights you find the right level.
Apr 04, 2014 | Kirby Vacuums
I took the vacuum apart and cleaned it. Now there is an odor coming from the round filter and the vacuum is not picking anything up.
  • hi there
  • Does the odor smell like burnt rubber....if so you may have burned out the belt which is common. The filter can smell if you have pets and the machine will blow the odor back in to the room after the filter gets older.Check to see that the roller brush is spinning when it is turned on if not shut it off and try to turn it manually with your hands. If it turns very easily the belt gone if it is almost impossible to turn you need a new roller brush.You can replace the filter to help with the smell but if it is the belt you smell it will go away in time. Also make sure that you have the container on perfectly as if it is not it will not create a perfect seal and you will have very little suction. The other thing you can check is the hose to see if the suction is good through it. If the hose has good suction then the power head may be plugged with something and you will need to get a screwdriver and take the bottom plate off the same way as if you were changing the belt and then you can look for a blockage as well as access the belt and roller brush. I hope this was helpful to you ...good luck
Oct 13, 2010 | Fantom Vacums Cyclone XT Upright Vacuum
No suction in hose
Remove the machine side of the hose--is there suction at the machine? If so, run a broom handle or similar through the hose to dislodge the clog. If no suction at the machine, you may need to fish out debris with a hooked stiff wire from the port. Remove the bag and examine the port area underneath for similar clogging. Finally, check the brush area underneath the machine bottom plate for more obstruction. Also, check the brush assembly for debris accumulation. Remove the drive belt and check for free turning of the brush. If turns hard, remove the brush, clean the bearings and roller pins, then apply a small quantity of light oil like 3-1 or sewing machine oil. Hope this helps!
Jun 20, 2010 | Lindhaus 380 Diamante Bagged Upright...
When I turn on mt dyson is sounds normal. once I
With the DC14 in its upright position, and looking from the back, there is an access hatch just to the right and bottom of the dust canister. Remove this and check for any obstruction. With the hatch still removed, tilt the handle back (as if vacuuming a floor), and you should spot that the mechanism in to which the access hatch fits changes over from one hole to another. This is how suction is transfreered from the telescopic arm to the brush bar when the unit is taken out of the upright position.
With the handle tilted back, the hole you can see is one end of a flexible pipe that leads to the brush bar. Check for any blockage and/or foriegn objects. If there is no obvious problem, you'll need to check the other end of the pipe. You can do this by removing the toe plate on the bottom of the brush bar area. The plate is held by 3 or 4 half turn fasterners - a 5 pence piece is ideal for undoing these.
If still no joy, the only other thing it might be is that the brush bar isnt spinning - this isnt actually lack of suction, but without brush rotation any upright hoover is far less effieicnt at picking up bits from the floor. Brushes not spinning on a DC14 is quiet a difficult thing to fix on a DC14 as there are two separate rubber belts, one of which is hidden under a plastic cover. There is also a clutch mechanism between the belts that can cause problems some times.
Oct 09, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
The brushes will not turn when on and cannot move them even manually
Drive belt has most likely broke and jammed inside the power head. Remove the bottom plate on the power head and replace the drive belt.
Oct 07, 2009 | Kenmore 25512/ 25513 Progressive Canister...
How to clean the power brush on the miele vacuum. Is the brush removable? If so how do you remove it?
Greetings from GoVacuum.com,
Miele canisters have 2 different types of power brushes. The first, and most popular is the Miele SEB 217, and 213 Power heads. To remove the brush, follow these instructions.
On the bottom of the power head there are 2 yellow (older models it is black) plastic screws. You can remove these screws with a phillips head, or flat head screw driver. Simply unscrew these two screws. You do NOT have to remove these screws, just unscrew them to where they are loose enough to remove the bottom plate.
Once you have unscrewed the plastic screws, simply pull the bottom plate up and off of the power brush. You will notice the belt on the left hand side of the brush. Simply pull the brush up, and un hook the belt from the brush;
Now that you have unhooked the brush from the belt, you may thoroughly clean the brush, and un wrap any hair or thread that is wrapped around the brush. You will notice on the roller brush itself there are two indentions on both sides of the brush that run the entire length of the brush. You can take a knife or scissors and run them down the brush on both indentions, which will help you remove the stubborn debris wrapped around them.
Also you'll notice on both sides of the brush that there is a yellow bearing cap on both sides of the brush. You may pull these bearing caps off, and remove any debris that is around these caps. You may also lubricate these bearings with grease or WD-40, to ensure the brushes spin fluently.
After you have cleaned the brushes and bearings, insert the brush roller back through the belt, and into the power brush. You'll notice that the bearing cap will have two sides. One side of the bearing cap has 1 groove in it, the other side has 2 grooves.
When you reinsert the brush back into the power brush, you may lower the roller brushes if the machine has been used a lot. If the roller brush is older, you will want to re insert the brush with the side that has 2 grooves facing upwards, and the side with 1 groove in it, facing down. In the first picture above, you will see that the side with 1 groove is facing upwards and is visible to the camera. The side with 2 grooves is facing down. This is because this brush is new. If your brush is older, you will want to reverse that, and have the side with 2 grooves facing upwards. When the brush is back into the power head, simply put the bottom plate back on, (IMPORTANT! Make sure that in the front of the machine the bottom plate is completely hooked onto the front of the power brush, there should NOT be any space in the front) Once you have screwed the plastic screws back into the power brush, in the front of the power head, push the bottom plate upwards to make sure there it is fastened tightly in the front.
I hope this helps you. If you have the larger, less popular SEB236 power brush, just send me an email, I'd be happy to walk you through cleaning the brush on this one also. If you have any questions about this repair, please feel free to email with any questions, I really enjoy sharing my knowledge, and passion fixing vacuum cleaners.
Chris Jones
GoVacuum.com
[email protected]
Sep 29, 2008 | Miele Vacuums
Brush is not rotating.
Turn the vac over, remove the access plate, covering the brush roll, 2 to 4 screws. Brush roll part number is 2032032if you need it, belt is a Bissell Style 7. While you have the brush roll off, check in dirt inlet to see if it is clogged, also check the hose to see if it is clogged. You won't feel suction at the bag tube, it has to have a bag on it and the lid closed before it will create suction.
Dec 29, 2007 | Bissell 3522 PowerForce Bagged Upright...
Lost suction
Hi.
Remove the sole plate turn the 3 plastic screws to unlock & lift off.
Now remove the blockages that have accumilated from the oppening of short clear hose.
Check you can turn brush roller & check belt.
Now reassemble switch on pull handle back & look under machine is brush spinning ?
If not check the knob on side of machine is in drive (D) position.
http://dysonmanuals.llc.nu
Chris..
Dec 27, 2007 | Dyson DC07 Animal Bagless Upright Cyclonic...
Vacuums Logo
Top Rowenta Vacuums Experts
Andrew Taylor
Andrew Taylor
Are you a Rowenta Vacuum Expert? Answer questions, earn points and help others
