Hillsdale Furniture Stanton King Canopy Bed Set by Hillsdale - 1751BKPR: Stanton Queen Canopy Bed Set - by Hillsdale - 1751BKPR Logo
S
Sherry Grimm Posted on Apr 25, 2014
Installation bed problen with affixing side rails to headboardlem the holes do not line up and are two different measurements
Fred Oakes
Level 1:
New Friend:
  • Contributor 13 Answers
  • Posted on Apr 25, 2014
Fred Oakes
Contributor
Level 1:
New Friend:
Answers
13
Questions
0
Helped
1547
Points
32
Just a guess but try the rails on the opposite side of the bed.
How to assemble Ashley bunk bed b213-58n
Contact Ashley Furniture to request assembly instructions.
Feb 28, 2021 • Furniture
How do I known if the front frame rails are bent
The checking of the frame rails for accident damage can be done easily. First place the vehicle over a flat clean cement floor. Select points on the frame rails such as front ends---suspension points---brackets attached to the rails on both sides and rear ends of rail. Make sure the points selected have a corresponding point on the other rail. Using a plumb bob drop the selected point to the floor and make a cross on the floor at that point. . Repeat the process for each selected point. The more points the easier to find where the rails are bent and by how much. Move the car out of the way and using a tape measure the distance diagonally between same points.-- EI-- from left hand front end to right hand rear end. Repeat the measuring from the opposite corners By measuring from one point on one side to the second point on the other side you will develop a continually crossing pattern of measurements. So in the end if you selected 4 points per side you will have 3 sets diagonal measurements on the floor or more . As you measure write the dimension on the floor. Now if there is a difference of more than 1/4 "(6mm)between any set of diagonals you will see if the rails are bent and if they are bent right or left or bowed in the middle. By measuring the heights of the corresponding points and recording them you will see if the rails are bent up or down. I understand it is a bit long winded but you will be in effect transposing the measurements of the points of the rails onto the floor so that the differences can be measured without the problems of items interfering with straight line distances.
1helpful
Lost machine bolts for louis philippe sleighbed
You can pick replacement up at a hardware store. If you need to figure out how long just line up the holes the bolt goes through, put a straw or somthing like it through, mark the depth and that is the size you need. I am guessing it is about a 3 1/2 inch long bolt at 3/8inch in diameter....may be a 1/2 inch in diameter.
I have a Jardine enterprize crib model:Da 822 bc
You can try locating the bed rails at www.csnbaby.com . They carry several different brands of the conversion rails.
Apr 11, 2012 • Baby Gear
1helpful
Replace shower door
Hi
You did not mention any additional information about your problem except replacing shower door.However use basic hand tools to complete the job.
Try this following general steps :-
1. Remove the doors by lifting up on one door at a time and then pulling each out. The top of the door has rollers attached to it, and the rollers rest on the inside of the top rail of the frame. Set the doors aside.
2. With your drill, remove the two screws on each end of the top rail, located on the inside of the shower frame. Then lift off the top rail of the shower frame.
3. Use your box knife to cut the caulk on the side and bottom rails of the shower frame. Shower frames are caulked on the outside where they meet with the walls and floor of the shower.
4. Use your drill to remove the screws from the side rails. There will be two screws on each rail, securing it to the shower stall. Then, take the rails out. Remove the screws from the bottom rail and take it out.
5. Use your tape measure to measure the old side rails, top rail and bottom rail. With a pencil, mark the lengths on each new rail. Use your hacksaw to cut each rail. Hold a side rail in the exact location where the old rail was located. With your pencil, mark the screw holes on the shower wall. The new shower frame screw holes may not line up with the old shower frame screw holes. Use your drill and 3/16-inch drill bit to drill new holes if necessary. If the shower walls are ceramic, use the concrete drill bit. If the shower walls are fiberglass, use the multipurpose 3/16-inch drill bit.
6. Insert the 3/16-inch anchors into the holes that you drilled. Put the side rail into position and insert the screws into the holes. Use your drill and Phillips head drill bit to tighten the screws. Place the bottom rail into position and mark the holes. Drill new holes if necessary and install the anchors. Insert only one screw at the end where you installed the first side rail. Lift up the loose end of the bottom rail and slide the second side rail into place. Mark the holes. Remove the side rail and drill the new holes using the 3/16-inch drill bit. Insert the anchors and put the side rail back into place. Insert the screws and tighten with your drill using the Phillips head drill bit.
7. Set the top rail directly onto the side rails. In each end of the top rail, insert the two self-drilling screws until the top is secured to the sides. Insert the tube of clear caulk into the caulking gun. Cut the end off of the tube with your box knife. Caulk the side rails and the bottom rail to the shower walls on the outside of the shower. Re-hang the shower doors by lifting each door and placing the rollers on the inside of the top rail.
Also giving you some links from where you can find a detailed information regarding replacing shower doors.
http://www.diynetwork.com/how-to/how-to-replace-a-shower-door/index.html
http://www.thisoldhouse.com/toh/how-to/intro/0,,214441,00.html
Thanks for contacting fixya.com
Please do get back to us for further query.
Jan 20, 2012 • Home
1helpful
Graco 3-in-1 crib instructions
Check this CPSC link.
Most if not all of the simplicity brand cribs have been recalled reguardless of whether they had wood or metal mattress supports.
There were 2 different recalls on the wood version but both were recalled for the drop-side issues.
This link specifically includes the Aspen 3 in 1 cribs and model #: 8740
We took ours to our local walmart last summer (we purchased it in a different state almost 8 years ago). I brought to cpsc report with me. They had not issue with the recalled information we has matching it to our crib. It did take the clerk a bit to find our crib in their system because it was older, but once she did we recieved a full refund, without a receipt.
As far as changing them to a toddler bed. When we converted ours to a toddler bed we simply removed the drop-side from the crib. The drop-side parts can be unscrewed from the side rails. Then we screwed the toddler rails to the bottom of the crib. Ours had screw holds for the toddler rails on the mattress support. If you do not have the holes for it, then you may have put the mattress support on backwards ie with the side that has the holes for the toddler bed rails on the backside of the crib.
1helpful
I need directions for the ellis simplicity 4 in 1 crib,
I have 2 versions of this crib...You take off the front rail... leaving the sides intact. You should move the bed rail up to the second holes...not the very bottom...or else the crib becomes even more Wobbly. After that you can attactch the toddlder rails to the 'side' rails...and one more screw (one on each) at the bottom of the toddler rail where there is a little metal bracket...attach that to the metal bed rail.
9helpful
6answers
Jardine convertible crib instructions
Hi, I know it looks hard but It's really simple .just take out the screws that are on each side on the bottom and top 1 on the top and one on the bottom each side( 4 in total )(Sides not on the front) and that's it, the front part comes off and you save it for when you make the bed a full size bed wich that part becomes the foot board. Hope this information helps! Good luck!!
Jun 11, 2008 • Baby Gear
14helpful
Convert crib to toddler bed
I finally found my instructions!! It's actually really easy to convert to a toddler bed:
Step one: Take out four screws (two on each side) of the front railing and top bar. They are the screws holding the front railing and the top bar to the side of the crib and the dresser.
Step two: Lower the mattress to the lowest setting.
Step three: Place the toddler bed railing in place. It can go either way depending on which side of the crib your toddler sleeps. We put the taller part of the toddler railing closest to the dresser because that is where our son's head usually is.
Step four: You'll need 4 1.5 inch hexagonal screws to screw in the toddler railing. After 2.5 years, I could only find two of them, so I used two 1.5 inch regular screws that came with the crib. On the taller part of the toddler railing -- the screws go into the 1st and the fifth holes. On the shorter side of the railing, the screws go into the 3rd and the 5th holes.
That's it.. You've now got a toddler bed!
11helpful
4answers
Convert to toddler bed
They do have answers on their website, you may want to check your printed or online crib instructions to remind yourself how you put the crib together, too.
I found the answers here:
http://www.pali-design.com/index.php?path=customer_services&template=faq&section=customer_services&subsection=faq&page=faq
i've pasted them below. You can make it a toddler bed without a side rail just by removing the movable side of your crib, and you can install the side rail instead of the movable side if you want it to look a little more finished and help keep your child from rolling out of the bed.
FAQ
How to convert a crib into a toddler bed
To convert a crib into a toddler bed you must loosen the two front gold bolts left and right side of the crib and remove the dropside (the front gate that goes up and down). After removing the dropside be very careful that you tighten back your two gold bolts.
How to install the streight rail (toddler rail)
To install a streight (toddler) rail loosen the two front gold bolts left and right side of the crib and remove the dropside, once you have removed the dropside replace with the streight rail. Always be very careful and make sure you tighten back your two gold bolts in the front.
Top Hillsdale Furniture Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Hillsdale Furniture Home Expert? Answer questions, earn points and help others
