E5 network problem
What's your Network Provider?What's your Nokia E5 Network Exact Problem?
1.Is your mobile Network has Lower signal or No signal?
You can try to switch OFF your mobile and switch ON to check Network strength.
2.Is your mobile display show "NETWORK ERROR" message?
You can try to check the below instructions:
1.Reinsert SIM in your mobile
2.Insert another SIM in your mobile
3.Insert Your SIM into another mobile
3.Is your Mobile Network Locked?
You can easily unlocked your mobile by using unlock code.You can contact your service provider and get the code.If they will not provide the code..You may look at safe and trustworthy online third party code providers, like Unlock-Zone.com where they will provide permanent unlock code with free unlocking instructions..Then you can use this code to easily unlock your mobile.
What's your Network Provider?What's your Nokia E5 Network Exact Problem? 1.Is your mobile Network has Lower signal or No signal? You can try to switch OFF your mobile and switch ON to check Network strength. 2.Is your mobile display show "NETWORK ERROR" message? You can try to check the below instructions: 1.Reinsert SIM in your mobile 2.Insert another SIM in your mobile 3.Insert Your SIM into another mobile 3.Is your Mobile Network Locked? You can easily unlocked your mobile by using unlock code.You can contact your service provider and get the code.If they will not provide the code..You may look at safe and trustworthy online third party code providers, like Unlock-Zone.com where they will provide permanent unlock code with free unlocking instructions..Then you can use this code to easily unlock your mobile.
Warning :
Do not enter any wrong unlock codes on your Nokia E5 mobile phones. If
you enter over a certain amount of wrong unlock codes on your Nokia E5
mobile phone, your phone may get hard locked and sometimes become
unusable.
1 - Switch on your Nokia E5 without any sim card.
2 - Don't bother as to what is displayed on your Nokia E5.
3 - Compose #pw+CODE+1#.
4 - The Nokia E5 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia E5 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia E5
Each Nokia E5 mobile phone has an unique unlock
code. You can buy the unique unlock code for your Nokia E5 mobile phone
using the form above.
