Question about Sony STR-DE845 Receiver
Parts diagram to sony str-de845 reciever
I need to see the wiring harness and fuse schematic
Posted by David Schoefer on
Steve K
    Genius:
  • Sony Master
  • 1,054 Answers
What problem are you having?
Posted on Apr 25, 2014
5 Related Answers
Anonymous
SOURCE: I NEED INSTRUCTIONS ON HOW TO CONNECT ALL COMPONENTS TO THE SONY STR-DE598 RECIEVER
codes for remote
Posted on Dec 23, 2007
Anonymous
  • 544 Answers
SOURCE: I need a schematic or service manual for Sony STR-DE345.
hi,
i can download it for you..
visit this site for manuals of your unit it will help you answer all your questions.
http://www.free-service-manuals.com/Detailed/15736.html
thanks,
you rate in our answers are much appreciated..
Posted on Feb 19, 2009
Anonymous
SOURCE: sony str-de845 powers on, relay clicks sound works
Hi there, can anyone help me? i cant seem to get my aiwa-d58 to get out of eco mode. no power, red light is on and every time i press the power button; the eco light clicks off and i no power supply to the whole unit. please help!
Posted on Jan 22, 2010
Jack Chambers
  • 99 Answers
SOURCE: I have Sony STR DE845
If you consult the card that came with the remote, you will find several codes for "Sony". You will need to experiment with each code until you find one that will power the receiver on and off. Then you will have control of the receiver. If you don't have the card, then go to the web site and download a copy in PDF format from there. I have a lot of Sony stuff, and I have found that the codes varry according to the year the equipment was made and its function.
Posted on Aug 31, 2010
dunnbiker
David Dunn
  • 8546 Answers
SOURCE: I have a Sony STR-DE845 receiver. The rear
Something is heating up to a point that it fails in the rear amplifier section. take it to a tech.
Posted on Jan 21, 2011
Bought a used sony str de845 with rm adu007, need program manual for rm.
If the remote is functionally the same as the original RM-LP204
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Sony-STR-DE845-Receivers-manual/id/387ci973/t/2/
Apr 11, 2011 | Sony STR-DE845 Receiver
Sony STR-DE845 5.1 Receiver, No Sound
Generally speaking, an amp protects itself from heat, shorts and overloads.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
Jul 11, 2010 | Sony STR-DE845 Receiver
Jan 01, 2010 | Sony STR-DE845 Receiver
Can't get subwoofer working with sony model STR-DE845 receiver
read the manual
First, it must be a self-powered subwoofer, then you've got some settings to select in the receiver.
Sep 15, 2009 | Sony STR-DE845 Receiver
My reciever turns itself off
You most likey have a wire short on your center or rear surround speakers. The wire short will be between the + and - points of the speaker wire.
To find the problem speaker, disconnect one of the 3 speakers at a time from the back of the sony and see if the problem goes away. Once you identified the offending speaker, check both the sony side and speaker side for the short. The small wire strands are hard to see and it only takes one to trip the protection mode, so look carefully.
Mar 07, 2009 | Sony STR-DE845 Receiver
hi,
thanks,
Feb 19, 2009 | Sony STR-DE345 Receiver
Sony atr-de845
Open it up, check by where the power cord comes in there should be a fuse. Check to see if it is blown. If so it is an easy fix. Replace the fuse with same type. If not the capacitors are gone and that is expensive to replace.
Dec 09, 2008 | Sony STR-DE845 Receiver
Sound Problem with Sony STR-DE 845 receiver
Check for bad solder connections and tighten any and all screws that hold the circuit boards to the chassis.
Nov 20, 2008 | Sony STR-DE845 Receiver
Sony STR-DE845 Receiver Logo
Top Sony Audio Players & Recorders Experts
aliasger yq
Alvin Barnabas
Alvin Barnabas
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
