I have checked wiring to tacho several times, all connections seem to be ok. Tacho starts working sometimes while driving or when I give it a couple a wacks with my hand.
SOURCE: 99 lancer,speedo tacho n gauge problem.
probably burnt or cracked circuit board on back of gauge cluster
SOURCE: Gauges all Dead
i think that u have a problem with RPM cause this problem is not always being with ur car.
SOURCE: i need instructions on how to install a tacho in a 2002 cg lancer
We had tacho installation problem with out 98 lancer with no tacho on the panel. we got a aftermarket one but when we had to wiring it up it needed a tacho signle from the ignition coil. The ignition coil is built into the distributor which made it hard. The 2002 is the same distributor setup as the 98 so you can get step by step instructions with diagrams and pictures from my page, you will see an link that says Mitsubishi Tacho installation. website is www.sureyya.biz let me know if you find it useful.
Goodluck
SOURCE: What do you mean cluster contacts bad !Whats the solution?
Remove the speedometer head unit, and check the soldered joints on the back. It's a common problem with these and some Chrysler products. "Randomly" is when the crack closes and makes contact, like if you hit the top of the dash and it starts working again. The speedometer head cluster.
Testimonial: "Great that explains it well Thanks"
