Motorola Mobility DROID RAZR M Logo
A
Anonymous Posted on Apr 24, 2014
My Motorola RAZR M, the motorola symbol keeps flashing, nothing works. Even rebooting does nothing. Has anyone else experienced this...what's the fix?
  • Official Brand Answer 1,623 Answers
  • Posted on Jan 14, 2015
Motorola Mobility
Level 0:
Answers
1623
Questions
0
Helped
350297
Points
5677
Contact Verizon for assistance.
Mark
Motorola Support
5 Related Answers
Anonymous
  • 91 Answers
  • Posted on Mar 09, 2007
SOURCE: motorola razr v3-wont turn on
many times problems with your LCD not turning on is a battery problem so try a new one. If you want to check if it is plug your phone in and if your LCD works get a new battery. Other than that if it still doesn't work your LCD is blown out. IF you have a laptop and don't want to get a new phone you can get a data cable and Motorola Mobile Phone Tools and you can use your phone from you laptop and that might work for you!!!
Anonymous
  • 63 Answers
  • Posted on Jul 13, 2007
SOURCE: Motorola Razr V3 speaker doesn't work
The speaker needs to be replaced.THE SPEAKER is located in the bottom section of the phone. You;ll have to remaove the bottom section with a t6 screwdriverand replace the speaker in this section. Sam!
Anonymous
  • 18 Answers
  • Posted on Dec 07, 2007
SOURCE: HOW TO INSTALL THE OEM Motorola RAZR V3 Keypad LCD Flex Cable
1), remove the bottom part (completelly)
a) do you know how to open the bottom part?
2) remove the cover on the top part
a) disconnect the keypad LCD Flex Cable
3) remove the two chrome "big screws" that allows it to open and close
4) CAREFULL!!!! WHEN YOU READY TO SEPARATE THE TOP PART FORM THE BOTTOM!!
a) make sure the Flex cable is loose, and take a screw driver, push the ping on the other side (try to do this at the edge of a desk or table) keep pressure until this side pops out. KEEP IN EYE ON THE OTHER SIDE!! that the Flex cable does not get cut out by separating the two sides.
5) Replace and pop the two sides together.
6) Put everything back together.
let me know if I need to be more specific
Anonymous
  • 290 Answers
  • Posted on Mar 16, 2009
SOURCE: Want to down-load user's manual for MOTOROLA RAZR V3g AT&T G
You can find them at www.howardforums.com
Anonymous
  • Posted on Jul 07, 2009
SOURCE: Bluetooth pairing on Motorola Razr V3
Razor V3m (Sprint) / Motorola H710 hands free. I believe my phones bluetooth is intermittent. I can get them to pair after about 15 minutes of trying, then once I open the ear piece it will not connect. The H710 will connect to other phone just fine.
Any ideas
I have a Motrola Razr V3a. Occasionaly the screen
there is a problem in the power strip of your phone take it to any of the servicing centres of motorola and get it fixed
2answers
Motorola Razar
That means the your flash cable has damaged. You have to call Motorola and repair it. Some time ago I have the same problem with my D&G phone
Motorola Razr V3m randomly/frequently is shutting off..
You need to take the phone to a mobile service center and have them flash the firmware on the phone to correct this issue.
Motorola Razr V3c freeze up
take the phone and have the firmware reflash to correct these issues
Motorola razr cant hear incomming call
that might be a little more work.
try your hands free, to see if you get sound
try someones else battery.
reset the phone to default.
This might help you to narrow the problem, If nothing works. you might haver to open it.
Paulo
16helpful
7answers
MIDlet suites
On games and Apps on my Motorola V3 Razr I keep getting the message "No Installed MIDlet Suite", How do i fix it?
Razr V3XX rebooting iteslf
hi
it seems your phone has a hardware problem... usually its flash ic.. have it reworked...
hope it get better...
8answers
Problem with the bluetooth on my motorola v3
HOPE THIS HELPS: http://www.motorola.com/mdirect/manuals/V3_9501A42A.pdf
MOTOROLA RAZR V3
man... it's a software and hardware problem... go to your nearest cervice center and they will fix it up.... 1st your problem is they have to check your firmware . but what i'm sure of is,, your going to change the flex, it's the ribbon part of your fone connected to the main board to lcd......tnx man...
Top Motorola Mobility Cell Phones Experts
AFIFUL HAQUE MUFTI...
Level 1 Expert
vince
john h
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
