Dell Inspiron Mini 10 Notebook Logo
A
Anonymous Posted on Apr 24, 2014
Rename user profile folder - Dell Inspiron Mini 10 Notebook
Steve Earl
Level 3:
Master:
  • Master 269 Answers
  • Posted on Aug 18, 2015
Steve Earl
Master
Level 3:
Master:
Answers
269
Questions
0
Helped
79918
Points
1290
Don't do it.. you won't be able to log on again as that user
I have xerox 3215 printer, and I'm using Chromebook. The printer works fine with google cloud till today. I received the following error: PWG ERROR - Incomplete Session by time out.Can u help me?
I'd suggest creating a new browser profile:
  • Exit Google Chrome completely.
  • Enter the keyboard shortcut Windows key+E to open Windows Explorer.
  • In the Windows Explorer window that appears enter the following in the address bar Windows Vista/ Windows 7/ Windows 8/ Windows 10:
  • %LOCALAPPDATA%\Google\Chrome\User Data\
  • Locate the folder called "Default" in the directory window that opens and rename it as "Backup default."
  • Try opening Google Chrome again. A new "Default" folder is automatically created as you start using the browser.
If you wish, you can transfer information from your old user profile to your new one. However, this action is not recommended, since a part of your old profile may be corrupt. With that in mind, to transfer your old bookmarks, copy the "Bookmarks.bak" file from the "Backup default" folder to your new "Default" folder. Once moved, rename the file from "Bookmarks.bak" to "Bookmarks" to complete the migration. All other browser data will remain in the "Backup default" folder, but you won't be able to transfer it to your new profile.
tip
How to rename or move a User Profile folder ?
To rename (or move) the User Profile folder, you may use the following method. This method has been adopted from KB314843, but this page explains in detail how to rename an User account home directory.
Though you can move or rename the user profile folder, there may be some side-effects after using this method. This is because of the reason that there may be some absolute path (to the old user profile folder) references in the registry, made by third-party software. Therefore, there may be a loss of functionality in some third-party software which stores the file locations as absolute paths, in the registry.
Before modifying the registry, you need to take a full backup, in case you want to Undo the changes or to recover from disasters caused by incorrect registry modifications if any. You may use ERUNT for a full registry backup. Use Registry Editor at your own risk
Rename the User Profile folder using Windows Explorer
  • Logon to an admin account that is not the account being renamed.
  • Open the Documents and Settings folder, by typing this in Start, Run dialog:
%SystemDrive%\Documents and Settings
  • The list of folders will be displayed. Select the corresponding folder of the user account that you want to rename.
Example %SystemDrive%\Documents and Settings\OldUsername
becomes
%SystemDrive%\Documents and Settings\NewUsername
Next step is to notify the registry that the folder has been renamed (or the Profile Path has been changed)
Changing the ProfileImagePath value in the registry
ProfileList key, SIDs and the ProfileImagePath value The ProfileList registry key contains some sub-keys, which are nothing but the list of User Account Security Identifiers (SID). Each of the SID represents an Account. The key is located here:
HKEY_LOCAL_MACHINE \ SOFTWARE\ Microsoft\ Windows NT \ CurrentVersion \ ProfileList
Identify the SID for your User account, and change the Profile path
  • To know the SID for your user account, you may use the script sidlist.vbs
  • Download the script and run it. (The User Account names and SIDs will be listed in a log file, and opened automatically.)
  • Note down the SID for your account.
  • Then, in the Registry Editor, select the correct SID that belongs to your user account.
  • In the right-pane, double-click the ProfileImagePath value and set the correct path and folder name. ( The ProfileImagePath stores the full path of the User account home folder. )
becomes the following:
You're done now. Close Registry Editor, and restart Windows. See if you're able to logon to that user profile successfully. Additionally, to verify if the path has been changed successfully, type SET in the Command Prompt. If you find any abnormal behavior while running an application (in case), you may Undo the above procedure. Then you may use the Copy To Profile method instead to accomplish your task.
Chrome will not open
Harvey,
You could try this:
-first, delete your current installation of Chrome,
-then, open Windows Explorer, and depending on your operating system, go to: %USERPROFILE%\Local Settings\Application Data\Google\Chrome\User Data\
for Windows XP
for Vista/ Windows 7/ Windows 8
-Go to the folder "Default" and rename this folder to "Backup Default".
-Now download and install Chrome again.
-Start it up. There should be a new folder "Default", created when you started using the browser.
If you value the data in your old profile: you can try copying them from the backup folder to the new profile, but some of it may be corrupted.
But at least your Bookmarks are not lost:
-go to the "Backup Default" folder, and -locate the "Bookmarks.bak" file. -copy it to the "Default" folder, and -rename it "Bookmarks". All the other old browser data is preserved in the "Backup default" folder, but transfering it to your "Default" folder may corrupt Chrome. Tread carefully, if at all..
User profile cannot be loaded
If you have an alternate profile on the machine, you can log in with that account and then find the folder with your profile and rename add ".old" to the end of it. When you log back in it will rebuild your profile and you can retrieve your data from the broken profile.
If you cannot access the profiles folder with another user account you will have to either use a Live Linux distribution or attach the hard drive to another device.
On Windows XP user profiles are located under C:\Documents and Settings\%profilename%
In Windows Vista/7/8 they are located under C:\Users\%profilename%
Where it says %profilename% you will need to change the corrupt profile and add .old to the end of it
  • This issue may occur if the user profile was manually deleted by using the command prompt or Windows Explorer by a user or by some program. A profile that is manually deleted does not remove the security identifier (SID) from the user profile list in the registry. Since the SID is still present, Vista will still try to load the profile by using the ProfileImagePath that points to a nonexistent path. Therefore, the profile cannot be loaded.
  • This can also be a issue with the user profile entering into a backup state.
  • Manually renaming the C:\Users\(User Name) user profile folder.
When I turn my computer on I try to gog in and it reads " user profile fail to load". What can I do?
By preforming the following steps, you may loose some documents, pictures, music, etc. Start your computer in safe mode. Do this by restarting your computer and pressing F8 once every 3 seconds until you see safe mode as an option. Select that, once you get logged in, open up my computer and navigate to:
If you have Windows XP follow these steps: Double click the C: drive Double click documents and settings Right click on the folder of your username and click rename and ADD a .old to the end of the folder hit enter, and restart your computer.
Now when you go to log in it will re-build your profile
If you have Windows Vista, or Windows 7 follow these steps: Double click the C: drive Double click the Users folder Right click on the folder of your username and click rename and ADD a .old to the end of the folder hit enter, and restart your computer.
Windows cannot load the locally stored profile. Possible causes of this error include insufficient security rights or a corrupt local profile. If this problem persists contact your network administrator.
It looks your profile is corrupted. You can login with administrator's login id other than the local profile user id and rename the old profile located in c:\documents and settings\ your user login name folder
and rename the folder. After that logout and login again with your user id, one having problem with profile and again go to the c:\documents and settings\ your user id name folder which you renamed and move your critical data on desktop or my documents to the new profile.
2helpful
I want to get my profile back
This can be a little easier than it sounds, but it takes a quite a few steps. The profile names only get extensions like .domainname or .thiscomputer if there is already a folder in the profile folder under the username. The easiest way to recover the original profile is to log in as another username with admin rights and follow these steps:
BE CAREFUL NOT TO DELETE ANYTHING YOU NEED!!! If in doubt MOVE to a backup location instead of deleting
Remove any "new" profiles under the same username
Delete (or move) the "new" profile folders, so that there are no folders in the profile folder under the username you want
rename the profile folder of the username you want to keep - i.e. rename it to "OldUsername"
logout and log in as the username you want
logout and log back in as your alternate admin user
look in the profiles folder, you should now see a folder with the original name corresponding to the original username folder you renamed. If that folder does not exist, something is not working right - you'll need to give me more information before I can tell you what.
copy the contents (make sure you have your view settings set to show all files, including system files) from the renamed profile folder (OldUsername if you used my suggestion) to the newly created profile folder. Overwrite anything that exists in the folder.
Logout and log back in as the desired username. All settings should be restored.
These steps are dependant on continuance of profile foldernames. The "new' Profile folder MUST be the EXACT name of the original. This is because many items in the USER.DAT (user hive of the registry) point to folders by name. If you don't get the foldername correct, the process will not work.
Desktop Not Displaying after User login
rename the user.dat in the user profile. you must be theadministrator to do this.have the user login again, that will recreate a new profile and new user folder. you can copy all of the items that are on on the new desktop from the old user profile folder.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
