Question about Clarion DXZ655MP CD Player
Deawoo wireing what color wire goes where when putting in new stereo
Posted by Elizabeth Thomas on
Timothy D
  • 626 Answers
Not sure what Daewoo Model you have, but this place has 3 models listed.
Just click on the Stereo link on the right side of this page;
http://www.the12volt.com/installbay/vehiclewiring/1/yeard/Daewoo.html
Best of Luck.
Posted on Nov 03, 2007
I have a toyota trueno 1992 and i want to put a new stereo in it
Go to the auto parts store and get a wire adaptor made for a 1992 trueno. It will plug into your factory harness. The wire colors are prematched to your sony and other aftermarket stereos. Just match the wire colors, splice with connectors making sure no wires are exposed. (A little electrical tape for good measure around splices helps). Then it just plugs in. If your factory stereo has mounts that screw onto the radio, unscrew them and attach them to the sony. Remove sleeve from radio and discard. The screw holes are already on the sony.
Dec 29, 2012 | Cars & Trucks
Please Help I Need A 1992 Mercury Capri XR2 color-coded Stereo Wire Harness Diagram
Go to your local auto store and get the Hanes auto manual for this care and they should have a wiring schematic for you to follow also you can look your new stereo up on the web and find out what each colored wire goes to what!!! Good luck
Jun 07, 2012 | Lincoln Cars & Trucks
I had my radio stolen out of my 1989 dodge dynasty. i need to know what the color wires mean on the car to be able to put in my new radio.
Here's the list of color code for your car :
1989 Dodge Dynasty Car Stereo Wire Color Codes
Car Radio Battery Constant 12v+ Wire: Red
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Black
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: Orange/White
Car Stereo Antenna Trigger Wire: Yellow
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 3 1/2′
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Green
Left Front Speaker Negative Wire (-): Green/Yellow
Right Front Speaker Positive Wire (+): Purple
Right Front Speaker Negative Wire (-): Purple/Yellow
Car Audio Rear Speakers Size: 6′ x 9′ Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Brown/Yellow
Right Rear Speaker Positive Wire (+): Blue/Red
Right Rear Speaker Negative Wire (-): Blue/White
Mar 01, 2011 | Pioneer DEH-P44 CD Player
I cant get a stereo hooked up
Your question is not very specific but I expect that you have discovered that Volvo does not bother to color code their sound system wiring. They seem to use whatever wire they have laying around, so there is no particular pattern, and often all the wires are the same color.
If your car still has the original stereo plugs, you can buy a wiring kit from the installation shop at Best Buy. It will have a plug that plugs into the Volvo plug and wires that are color coded to standard color coding so you can figure out how to connect it to the new stereo. I not only had to put in a new stereo, but I had to bypass the original amplifier in my '91. The kit from Best Buy made it all Plug and Play!
Jan 22, 2011 | 1989 Volvo 740
Putting in and new stereo system in a 1994 oldsmobile eighty eight and need to know the color of the power wire and speaker wire
When I put a new stereo in that is aftermarket, I get a wiring harness from Best Buy or Ebay.com that has the wires labeled for easy hook up of speakers and power, etc.
Sep 18, 2010 | 1994 Oldsmobile Eighty Eight
Hooking up a new stereo
Go by a stereo shop and get an adapter for your car. It connects all of the correct wires to the aftermarket radio without damaging or removing wires from old connector.
Sep 13, 2009 | 1988 Cadillac Sedan DeVille
I need help with a wiring layout for a stereo.
Forget it...go to a car stereo installation shop and buy a wiring harness for your car ($20-40) and you're done!
Good Luck
P.S. might as well buy a dash kit ($30) to make installing the radio simpler as well...if you DON'T have a car stereo shop nearby, order parts from crutchfield.com
Jun 23, 2009 | 2007 Hyundai Sonata Limited Sedan
Puttin new speakers i dont know what color the stock speaker wires are
2002 Chevrolet S10 Pickup Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Orange
Car Radio Switched 12v+ Wire: Dark Green
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Violet/White
Car Stereo Antenna Trigger: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Apr 16, 2009 | 2002 Chevrolet S-10
I need the color codes for a 1988 GMC Sierra stereo.
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: N/A
Car Audio Front Speakers Size: 4′ x 6′
Car Audio Rear Speakers Size: 5 1/4′
Car Audio Rear Speakers Location: Rear Doors
Mar 03, 2009 | 1998 GMC Sierra
Clarion DXZ655MP CD Player Logo
122 people viewed this question
Top Clarion Car Audio & Video Experts
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
