Question about 2002 Hyundai XG-350 - All XG300/350 models - Base Rack System
Can you replace radio modelh-940hl with model h-942hl? on a 2002 xg350 hyundia
Replaced, came on, but no sound. not lock out. tune stations ok.
My honda accord radio has been decoded but the volume is not functioning. why is there no sound and one cannot tune in to any station?
Was it just replaced? No tuning is the antenna wire wasn't plugged in. It would get stations manually, but with static. Not lock by itself. No sound could be a bad replacement radio or an amp. Check the amp fuse first.
Jan 17, 2015 | 2004 Honda Accord Sedan
I put a replacement radio in a 1994 Olds Cutlass Supreme radio makes noise in right rear speaker when tuning in station.
Hi JPLP, A popping or 'motor boating' sound is usually a sign that one of the transistors is defective. As it happens only when tuning in the radio it is possibly in the pre amp stage. Regards John
Aug 19, 2012 | Cars & Trucks
I knave a teac model ex cd3. Have lost the manual. Can't remember how to reset the radio stations. Can you help?
OK press power on,select tuner button for radio. then select band AM or FM. Then press tuning mode button until you see [manual] in the window. then press the tuning button [arrow left or arrow right buttons] until you get to your desired station.then press program / memory set. a memory number will flash [ say memory 1]. then press program/ memory /set button again to lock in the selection [memory 1] now this is the TRICKY PART. Once the selection is memorized go back to tuning mode Press the tuning mode button until you see manual and i think you can follow the above procedure. If you program AM stations first Then press the BAND button to get FM stations and go back to step one.
Feb 17, 2011 | Teac EX-CD3 CD Shelf System
2004 NISSAN SENTRA . THE VOLUME OF THE RADIO STOPPED WORKING. THE KNOB WORKS, THE BUTTONS FOR DIFFERENT RADIO STATIONS WORK. THERE IS JUST NO VOLUME.
same this happned to me in my 2006 sentra. the volume for the radio is gone. i can tune, its just barely audible/ quiet. weirdly though it sounds perfect when playing CDs. i almost thought maybe it got switched in to mute mode or something. did you figure out your problem?
Jun 17, 2010 | 2002 Nissan Sentra
2002 XG 350. License plate bulb out. How do I pull bulb, wiring is too tight. Thanks Joe B
2002 HYUNDIA XL 350, LIC. PLATE BLUBS CAN NOT GET ASSEMBLY DOWN TO REPLACE BLUBS, DUE TO THE FACT THE WIRES ARE TOO SHORT TO PULL UNIT DOWN. ANYH IDEAS?
Oct 30, 2009 | 2002 Hyundai XG350
How do I fix the car radio
You can grade me on step one.
1.) Find the fuse panel inside the car and check the radio and cigarette lighter fuse(s). If your fuses are OK, then:
2.) Remove the radio from the dash to have it checked.
Jul 28, 2009 | 2002 Hyundai XG350
Front wheel stud broke off
Knuckle needs to be removed and the center hub 'pressed out' using a hydraulic press (accepted procedure). You can avoid this by using an air hammer and disk cutting tool to remove the old stud, then trim the 'stop flange' on the new stud (1/4 moon cut) in order to install it.... however, you gotta know what you're doing so you don't compromise the integrity of the new stud.
Jul 04, 2009 | 2002 Hyundai XG350
Can't fuel xg350 2002 at gas station difficult
there is a tube that runs along side the filler neck to the gas tank, this tube allows air to escape from the gas tank as you fill it, if it gets kinked or obstructed then you have a hard fill situation, pull the filler neck/vent assembly out and replace it.
Apr 09, 2009 | 2002 Hyundai XG350
Heater blower problem
under the hood of the car on the passenger side you will see a round motor sticking up.thats the blower motor there should be 3 screws holding it in place and one plug to unplug.you lift the old motor out and put the new one in in its place
Jan 13, 2009 | 2002 Hyundai XG350
2002 Hyundai XG-350 - All XG300/350 models - Base Rack System Logo
Top Thule Vehicle Parts & Accessories Experts
Nicola Conroy
Don Walper
Level 1 Expert
Are you a Thule Vehicle Part and Accessory Expert? Answer questions, earn points and help others
