SOURCE: NComputing L230 won't connect to host
First Please check your Lan IP Address for host pc.
change IP address and subnet mask on L230
disable firewall or any antivirus that is blocking ports.
Then you will get connected.
SOURCE: NComputing connected to existing Lan network
If your existing LAN has DHCP assigned IP addresses, you will be good to go. If you have statically assigned IP addresses, you will need to enter them in manually into the device. Their website has a very good instructional video on the procedures to hook up the devices. It will work with standard cat5,cat5E, or cat6 wiring.
Testimonial: "Good and quick response."
SOURCE: How to connect Ncomputing L300 webcam
Ncomputing does not support webcam. U can read at ncomputing sites. Cheers....
SOURCE: ncomputing cannot connect to the
Please specify which Server 2K8 version you're using. If it's W2K8r1, and you had installed SP1 as of this posting date, their software didn't support SP1. They recently updated vSpace to support that so please either remove SP1 and retest, or update your vSpace software to the current version and you should be all set. Additionally, if you're server/host is a domain member, make sure it's a domain member when you install vSapce as the installation will manage the firewall port settings for you and many times those firewall port settings change when a system as added to the domain membership.
