Sharp LC-32SB21U 32 in. LCD TV Logo
A
Anonymous Posted on Apr 24, 2014
How old? is it HD? - Sharp LC-32SB21U 32 in. LCD TV
Lawrence Oravetz
Level 3:
  • Sharp Master 10,558 Answers
  • Posted on Sep 12, 2016
Lawrence Oravetz
Sharp Master
Level 3:
Answers
10558
Questions
Helped
2697255
Points
29284
The build date is on the data sticker on the back of the TV.
How can I get the best HD (cable) signal to my old HD TV with no HDMI port. The TV only has Component Video, S-Video, RGB input, and of course Coax input. The TV is an LG DLP TV.
If it is an hd compatible tv the is has to have either an hdmi port or a dvi port. Our old projection tv was hd but before the current hdmi format so we had to use an hdmi to dvi conversion cable. If it doesn't have either of these then it probably isn't hd compatible.
My desktops ide devices are not connecting to it and error occures no bootable media
This sounds to me to be one of two things. Either your HD is not connected to the motherboard or your HD has crashed.
Step one is to open your tower and make sure the HD is connected to the motherboard.
Step two (if step one has been resolved) Replace the HD this will require you to reload your Operating System.(XP,Visat,Windows 7)
Step three once the New HD has been replaces and the Operating System loaded you can make the old HD a slave drive (second on the daisy chain) and copy the data from the old to the new HD.
1helpful
Have a HP SR1010V, 33GB HD - XP Home. Want to 1) replace HD with a 100-200GB HD OR 2) ADD a 100-200GB HD and 3) ADD a DVD drive. What is best way to copy data to a new HD and to boot the new HD. Rather...
The easiest route would be to install the new hard drive in place of the old hard drive and place the old hard drive below the new hard drive and make it a secondary hard drive or slave drive. Once you have them installed this way you can install Windows XP Home to the new hard drive once you have it installed to the hard drive then you can copy everything from your old hard drive to the new one. Once you have everything copied from the old hard drive you can then format it within Windows to have 33GBs of space to store anything you wish. If you need more detailed instructions don't hesitate to reply.
2helpful
Copy Contacts to HTC HD
first tranfere the contacts from old mobile to outlook, then sinc the htc hd with outlook which tranferes the contacts to your hts touch hd
BOOT.INC default= signature
Your old hard drive contained files used by the OS, as well as the OS itself. If you replaced that HD with another, and did not clone your existing install onto the new HD, then there is no boot record, nor is there anything to boot. It is not possible to just swap a HD and expect it to work without either cloning the old drive or performing a fresh install of an OS. The fact that it is detected by the BIOS is good, as you can install a new OS onto the new drive, or use a program like Ghost to clone your old drive's contents onto the new drive.
1helpful
I bought an All-in-One Multifunctional Converter (Coolmax CD-350-combo) to transfer my data from my non-working laptop to my new laptop. The problem is that it doesn't fit into my hard drive. My old laptop...
I have spent hours trying to figure out how this damn thing works since the instructions require the user to have way more computing skill than I. First, the thing comes apart, one part being the interface and additional power supply and the other being the power supply that may connect to the Coolmax or your HD power supply if not operational through the Coolmax. If your old HD is larger than 3.5", you may have to connect the power plug to the HD 4 pin power source. otherwise, connect old HD to the Coolmax CD 350 adapter and then connect the Support USB2.0 to a USB interface on your new computer. If your old HD is a 2.5 SATA , do not connect the red power plug to a USB2 interface on your new computer unless you are positive the old HD operates over 5V. Connecting the red USB power source to your new computers USB2 interface may cause the old HD to shoot sparks and smoke, and you will not need the device any more.
BOOTING FROM XP OS INSTALLED ON A USB HD
Yes U can enable Boot from USB device ...& first boot device must be USB Hard Disk...
How to install seagate ata IV hardrive
The easiest way to upgrade from your old HD to the new 40Gb HD is to clone the old to the new. Do a google for "hard disk clone" freewares. Personally I use Partition Magic and have had very good results.
Hardware wise, you need to install the 40Gb as a slave to the old HD by connecting the same IDE cable as that of the old HD (you may have to remove your CD/DVD temporarily). You also have to temporarily remove the single jumper of the 40Gb to allocate it as a slave to the primary master (old HD). Plug in likewise the 4 wire power connector. On power up go to your CMOS/BIOS setup to verify that your PC autodetect the 40GB (you may have to do a manual detection). Boot your PC and go through the normal boot sequence. Thereafter download your clone software choice, install and run. Follow on screen instructions. You may need to reboot. After completion, use Windows Explorer to verify that everything has been copied. Power down, remove the old HD, relocate IDE cable connector of the old HD to the 40Gb, reconnect your CD/DVD, and place back the jumper of the 40Gb. On popwer up go again to your CMOS/BIOS to verify that the 40Gb & the CD are detected. Save & exit, reboot.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
2answers
How to Install a new HD on Dell Inspiron 6000?
You can always parition the drive, and install both Ubuntu and XP (dual boot).
Yes, you will be able to access the files (providing the drive isn't totally crashed), although Ubuntu may not "know" what the files are.
Top Sharp Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
