Question about Konica Minolta Bizhub C451/c550/c650 Toner Magenta A070330
Iam getting p21 c650 and developer - Konica Minolta Bizhub C451/c550/c650 Toner Magenta A070330
Norman J Weimar Jr
  • Konica Minolta Master
  • 6,960 Answers
Color registration is off check the sensor under the transfer belt and mite want to have e tech run color registration procedure. black is the reference for the color registration having developer problems with black drum does not help
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Jan 10, 2016
My c353 konoca Minolta is showing p7, p8, p21 and it print test page with black and cyan only.
Replace the black drum and developer unit along with the magenta (P-7) and yellow (P-8) image units and Transfer belt (P-21)
Dec 07, 2017 | Minolta Office Equipment & Supplies
My copier can't print yellow color and p21 and p8 show on the screen. any clues
P21 & P8 are errors of yellow drum cartridge, replace yellow cartridge.
Aug 04, 2015 | Konica Minolta BizHub C650 Copier
Konica minota c650 Printing balck baground copies
replace the black image unit. and ensure modification lock is installed to ensure proper connection if you pull out the black image unit is there black developer piled up in the rear???????
Jun 20, 2015 | Konica Minolta BizHub C650 Copier
Where in florida can I get a malber p21 washer and get the dementions of it. I have one in NY and love it
A Malber P21 has the following dimensions:
Height:33 1/2"
Width:23 1/2"
Depth:20 7/8"
(From the AJ Madison Web Site)
The model is discontinued, though.
http://www.ajmadison.com/cgi-bin/ajmadison/P21.html
The current model is the P31.
It's an Italian model sold primarily in the New York area.
You may want to call Malber at 516.323.5299. or email [email protected]
Oct 17, 2014 | Malber P21 Front Load Washer
C244e prblem for p 21 errof code
Replace the black drum and black developer unit P-9 Black drum issue and P21 registration issue since black is used as the reference for registration of colors can see a P-9 and P-21 code combo. Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Jun 13, 2014 | Konica Minolta Minolta Bizhub C253 Copier
Erreur P21 konica C650
requires remove of the transfer belt and cleaning of the registration sensors located under the belt on the right side of the machine, with belt out requires knowing what lever to push to expose the sensor to clean them or the have them replaced.
Jun 08, 2014 | Konica Minolta Bizhub C451/c550/c650 Toner...
Error p21
as I said before Color registration is off check the sensor under the transfer belt and mite want to have e tech run color registration procedure. black is the reference for the color registration having developer problems with black drum does not help
Apr 24, 2014 | Konica Minolta Office Equipment & Supplies
What does the Error code C-225B means on the Konica Minolta?
I am unable to fix the problem C225B in Konica C450 please help me i have replaced all the tonner unit and Developer kit also.
Oct 18, 2013 | Konica Minolta BizHub C650 Copier
Konica Minolta Bizhub C451/c550/c650 Toner Magenta A070330 Logo
97 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
