G
Graeme Keep Posted on Apr 25, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
We have a wirless Microphone using with a xp510i itwas working OK but we think somepne has played with the knobs as I cant get the Mic to working through the speakers any ideas
EVERY NOW AND THEN SOUND COMES OUT IT IS INTERMITTENT
Glen
Level 2:
  • Expert 225 Answers
  • Posted on May 27, 2014
Glen
Expert
Level 2:
Answers
225
Questions
0
Helped
82195
Points
395
Process of elimination needed. Plug a corded mic into the wireless channel. Does it also cut in and out? If not then it sounds like the wireless is the one cutting in and out...not unusual for cheap units. Your wireless is not a cheapie? Then check the wireless squelch setting located on the receiver as it may be set too high.
1helpful
What do you do if the built in microphone for the Toshiba Satellite M305D-S4840 is not working (not picking up sound)?
SKYPE MICROPHONE PROBLEM
If the person cannot hear you then, either your microphonedriver not installed or not working OR the microphone is not configured inSkype.
To test your microphone then click on Start - All Programs - Accessories -Entertainment - Sound recorder. Then record your voice and then play it back.If this is OK then the microphone need to be configured in Skype.
To configure the microphone - Open Skype - Tools - Options -Audio Settings for the Microphone THEN click on Save.
1helpful
I just bought a new gigaware earclip monoheadset with mic. the problum is i cant seem to get the mic working the sound works great but i just cant get that voice to work
Hello Mithmar hi, try setting the volume for your microphone, (i'm assuming you are using X P) to do this right click the speaker icon (or the mixer icon) on the lower right side of your screen, you will go to the volume controls section, goto options, then properties, select recording. check the microphone, then click apply/ok. On the mixer there is now the microphone slider. Test your microphone by loading the sound recorder program (start, all programs, accessories, entertainment, sound recorder, press the red button) then shout to the microphone, you should see wave patterns on the recorder, your microphone is working fine. at this point let me know your progress.
2answers
Sound problem
please go to audio properties and adjust the volume of your microphone. or do the hardware test.
My microphone use to work but now it says when i click control panel to go to the sound and i test it, it says your sound hardware cannot play sounds, it use to work fine. and its not muted because i...
the grey means its not finding the mic. plug the mic into another plug for the mic. if it still is not working then your mic card slot might not be working.
Did I kill my NT1A Condenser Microphone?
This mic has a pre-ampcircuit inside. It sounds like that preamp has a defective stage. What you are hearing is distortion. This is not something that can be repaired locally. This mic should be sent to the manufacturer for repair.
Dan
I bought a new behringer vmx1000. I can not get the microphone working.
What microphone are you using, and also have you checked the cable is good? The gain knob on the mic channel is the only independent control for the mic level in relation to the music (without altering the masters). Also, you need the mic to be enabled on the channel, using the Mic On switch. Yours might be labelled On Air, Mic Live, etc.
Turning off mic to use my headset mic
Normal 0 Go to Control Panel and Click on Sounds, Click on Audio, then Click on the Microphone. Then Click on the drop down and select your headphone mike or Camera Microphone.
Click OK and it should work.
Hope this helps. Bud
Microphone
go to device manager and check if there is mic internal or not-and check user manual sound section.
3answers
MIC
Does she have a microphone plugged in? I dont think the 6400 has a built in mic.
If you're sure your mic works then open the sound mixer (click the speaker icon by the time in the lower right) and click "options" then "properties" and select recording. Click ok. Make sure "microphone" is selected.
Hope this helps!
Top Samson Audio Players & Recorders Experts
 Grubhead
Grubhead
Arnie Burke
Arnie Burke
ADMIN Andrew
ADMIN Andrew
Are you a Samson Audio Player and Recorder Expert? Answer questions, earn points and help others
