I have the model phone as listed above, and I need help setting it up. It has no noticeable power plug, power port, or battery compartment. All the ports that it has are an RJ-11 handset port, an RJ-45 Cat-5e Ethernet port, and a speakerphone port that looks similar to the Ethernet port, but not an exact match in design. Please Help! I need to get this thing setup ASAP. Thanks.
SOURCE: Handset No Link To Base error and no dial tone
My battery is a Ni-Cd. I bought it new on eBay (TL26554 battery number). I allowed the new battery to charge for a long time and then tried to see if it would work. But no go....the handset gave me the same error message. Good Luck to you too! Mmmmmm
SOURCE: handset has No link to base
I was having the same problem with the same model phone, and fixed the problem by rebooting the phone – unplugging the AC and phone cord from the base station and plugging both back it, then removing and replacing the handset to regenerate the security code.
SOURCE: Handset ?No Link To Base? error and no dial tone
2/29 Have you registered or re-registered the handset?
"No link" can mean handset is not accepting radio wave of base unit. At Mfgr website pull-down operator's manual and look for registration instructions. Some sequence of buttons will create a radio signal from base (have handset off base) then another sequence of buttons on handset will accept radio signal. If handset has "menu" button, try "menu", then "00" (zero zero) then select an accept or "OK" button. Good luck.
SOURCE: compaq sr1950nx internet connect
Hi mp295,
Well click this link to Compaq Presario SR1950NX for software & Driver downloads. Pick you operating system here:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&cc=us&lang=en&dlc=en&product=3184153&
Good Luck & kind Regards
SOURCE: New Voice Mail flashing light
What worked for me was to call my phone from another phone and leave myself a voicemail. I then went in and retrieved and deleted that voicemail. Once I hung up from my voicemail service my handsets reset about 10 seconds later.
I hope this helps!
