Question about Rowenta Irons
Heat goes off and red light blinks - Rowenta Irons
Posted by bob denison on
Archie Cruz
  • 641 Answers
Hi Bob,
You may want to visit this link I have for you to check what is issue yo are facing and get resolve it. Hope it helps.
Rowenta Advancer Will Not Heat Up eHow
Posted on Apr 24, 2014
Teresa Bristol
  • 34 Answers
Contact Rowenta if the yellow and red LED lights start to blink; this indicates an internal electrical failure.
There are over 200 complaints on the consumer affairs website, that include same this problem.
Its better to be safe than sorry.
I just plugged in my new Rowenta iron for the first time and the red and yellow lights re blinking and it won't heat up.
It is evidently defective. If this was the first use, box it up and send it back for a refund or replacement. Most companies require to issue a return authorization form before shipping it back.
Jul 02, 2018 | Rowenta Irons
Why light blinks then goes off when switch is still in the on position
The thermostat in the iron controls the temperature of the iron. The red light indicates when the power applied to heat the iron which is set by the temperature dial on the iron. When it reaches the correct temperature the thermostat turn off the power and that is when the red light switches off.
Jan 15, 2012 | Irons
Iron won't heat up, the 3 lights of yello green and red blinking
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
May 03, 2010 | Rowenta DZ5080 Iron with Auto Shut-off
Iron won't heat
thermostat or element. replace.
Mar 26, 2010 | Rowenta Professional DE880 Iron
Red light keeps blinking and iron shuts off
Sounds as if the cable may be damaged or a loose connection. May be cheaper to buy a new one from wallmart or similar store.
Jul 31, 2009 | Rowenta Effective DX1900 Iron with Auto...
I'm having a problem with the auto shut off of my sunbeam 421A series iron. The iron works great until the auto shut off comes on and the red light starts blinking. I understand that the iron should...
Unless you have a 5 or 6 hundred dollar iron, or unless it is brand new, and still under warranty, there is an excellent rule of thumb when an iron quits working: Buy a new one! These days, irons can be purchased cheaply enough that it is WELL worth the money. Not just for the convenience, but for the safety issues. This is an appliance that could burn your house down even if it's in PROPER working order. Hope this helps!!
Chad
Sep 21, 2008 | Sunbeam 4214 Iron
Red Light Blinking
heatman101
Jun 11, 2008 | Krups V70 Iron
Red light flashing
Blinking red light is a standby phase, its not going to get hot like this. Shake it or just start ironing, the red light will go solid and the plate will heat up. The red light will go off when the plate is hot enough. It will go on again (solid) after a few minutes to keep the plate at the right temperature. If you leave it standing around for a while it will begin blinking again (standby).
These irons are known for malfunctioning though, mine stays in standby and the plate never heats up! Hopefully yours is fine.
Feb 07, 2008 | Braun SI6225 Iron
Irons Logo
826 people viewed this question
Top Rowenta Irons Experts
Colin Stickland
Colin Stickland
Paul Bade
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
