Philips Magnavox 50ML8105D 50" HDTV DLP TV Logo
A
Anonymous Posted on Apr 24, 2014
Why does my magnavox 52 inch dlp make a fairly loud humming noise for 10 minutes or so after turning the tV on? It gradually get quieter.
Jeff Mitchell
Level 1:
New Friend:
Problem Solver:
  • Contributor 8 Answers
  • Posted on Mar 12, 2015
Jeff Mitchell
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
8
Questions
0
Helped
5557
Points
11
It is likely a bad fan that gets quiter as it warms up from use. There are two fans on that TV - one under the bulb housing and one at the left vent hole. They are special fans with three leads - +, - and an RPM indicator (yellow lead typically).
5 Related Answers
Anonymous
  • 3459 Answers
  • Posted on Feb 13, 2009
SOURCE: colors don't line up
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Anonymous
  • Posted on Oct 08, 2009
SOURCE: old magnavox 52 inch big screen tv - screen rolls, jumps, loses c
the screen on my hdtv has alot of marks on it how do i get another
Anonymous
  • 135 Answers
  • Posted on Feb 23, 2010
SOURCE: Will turn the tv on and after a few minutes the tv
Could also be a bad fan.
Chi Chu
  • 8457 Answers
  • Posted on Apr 29, 2010
SOURCE: 37 INCH LCD MAGNAVOX TV WILL NOT TURN ON. MUST BE
This problems,very common in LCD tv,after the tv was in used about a year or two.The new technalogy LCD tv don't handle heat very well,not like the old CRT Tube Tvs.The power supply board tend to have bad capacitors componnents leakage,that bulges up it top or puff up gases escape,that why it take times or couples pushes to the power botton to turn the tv on.U know basic electronic's,and have soldering tools and solders?Take the tv aparts,check for these bad capacitors,that bulges,puff up in the power supply board and replaced them,than ur power will work normal again.Or tries Websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Anonymous
  • 14553 Answers
  • Posted on Aug 13, 2010
SOURCE: older 52 inch tv magnavox
There two possible things based on your description.
Go to a channel that is in black and white and examine the picture--is it black and white or yellow?
These sets do have screen controls that can be adjusted but they rarely need it.
If the picture is yellow looking it could be interpreted as too bright.
If good black and white picture---stand back ten feet when you examine it---I can tell you how to adjust the sceen controls, not real easy but can be done with someone to watch screen.
I am here to help you and I have over 30 years experience with all kinds of TV sets.
Is black and white picture somewhat YELLOW LOOKING?
iF THIS INFORMATION TOLD YOU SOMETHING YOU DID NOT know rate this solution as very helpful as I do this here for free.
If you have more information or need help comment here to this solution.
REGARDS, SD TECH
What may cause a high pitch hum.even when muted or volume turned down?
Samsung DLP making a buzzing noise, but works fine - High Def ...
www.highdefforum.com > ... > Rear-Projection TVs
Dec 11, 2009 - 7 posts - ‎5 authors
My Samsung HLP-5063 DLP starting making a loud buzzing noise recently. ... I've only used it to watch TV for a half hour or so at a time, as I have a new LED LCD in my room. ... Other than that, I can't figure out what might be causing it. .... a humming high pitch sound, it will be an issue with the color wheel. RCA D52W25 making high pitch noise - High Def ...
Apr 15, 2009
humming sound in my dlp - High Def Forum - Your High ...
Nov 6, 2006
More results from www.highdefforum.com
High pitched sound coming from my Samsung DLP TV - Open Forum ...
www.dslreports.com > Forums > Social > Open Forum
DSLReports
Oct 3, 2009 - 30 posts - ‎7 authors
Its so high pitched that some people can barely hear it, but I guess I have sensitive hearing. ... Anyway, this seems to be a fairly common issue and it is caused by either the ... You're probably hearing a transformer humming.
How do I fix loud humming noise in my DLP HLP4663W 42 IN Samsung TV?
I would start by checking all the cooling fans to see if one is dirty or possibly failing.
PHILIPS 50 Inch HD DLP Projection TV the picture went out suddenly and there is not sound but a loud humming-buzzing coming from the set...any ideas on what could be wrong or if it can be fixed?
It's the optical block (color wheel) and the same thing happenned to our Philips 50" DLP. From what I've read, it's not worth the trouble & $$ to fix. Dig a hole!
I have a 52" rear projection vivitek dlp tv. Picture is fine, but it has a loud humming sound. Does anyone know what it is or how to fix it??
turn on video mode if loud humming still occurred replace filter capacitor on audio section from your tv ckt board.
3answers
Our toshiba 42" DLP makes an incredibly loud fan noise sometimes. Sounds like it will blow up. Can this be fixed without costing a fortune or do we just need a new set
Hello.
I can Honestly say this is little information. and i will try to you to a web site that i think it will help you and probably you can fix it by your self.
http://www.fixyourdlp.com/forum/viewtopic.php?f=10&t=1254&p=4208#p4208
This is what i think is the problem.
id the sound is to loud i think its the Color Wheel maybe its broken or louse you need to check and see that you color wheel is not making the loud sound!
Good Luck on fixing your TV
1helpful
Making a lot of noise
Sounds like a bearing in the cooling Fan
Thanks for using FIXYA
1helpful
Humming fan
ok it could be a fan...or a colorwheel...turn the tv on....let it power all the way up...then shut down ...you are listening for WHEN the noise stops...does it stop when the lamp powers down..look @ the back to see this..if it does then it will need a colorwheel..if the noise is there for 5-10 minutes after lamp has shutdown then it is a fan...problem: there are 3-4 fans in the tv...which one is the next question...let me know what you find..
Hdtv dlp 52 inch loss of picture and loud buzzing noise
Please see http://www.fixya.com/support/t1011937-transformers. It sounds like your flyback transformer is not properly soldered down/is failing.
Tv has what sounds like a humming noise by where the bulb is
sounds like the color wheel problem.
http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
