Question about Epson Stylus Pro 7400/7800/9400/9800 Matte Black 220 Ml
Where to clear the counter motor on the epsom stylus 7800
Error 0002,how do I clear carriage motor counter
1 Related Answer
Anonymous
  • 118 Answers
SOURCE: clear the Carriage Motor Counter epson stylus pro 4800
look for that here
Posted on Mar 26, 2009
Tip
Epson Stylus Pro 3880
ERROR CODES CAUSES AND SOLUTION
1101
CR life error The CR scan path counter has reached a predetermined level.
(The end of life of the Ink Supply Tube)
Replace the Ink Supply Tube (INK, SYSTEM, ASSY) and reset the counter using the Adjustment Program. In addition, check the statuses of the CR motor (MOTOR ASSY.,
CR), the driven pulley, the Carriage Unit, and the Head FFC, if any abnormal noise or wear is found, replace the corresponding part(s) along with the Ink Supply Tube.1120
CR lock error The CR encoder failed to read the CR scale during a predetermined time period. Replace the CR encoder (BOARD ASSY., ENCODER, CR).
Replace the CR scale (SCALE, CR).The carriage unit does not operate due to a CR motor failure or some reasons. Move the carriage unit manually to check if it moves smoothly, and fix any abnormality.
Replace the CR motor (MOTOR ASSY., CR).1121
CR reverse error An abnormal operation (reveres movement) of the carriage was detected a predetermined number of times. Check the CR scale (SCALE, CR) for incorrect attachment, scratch, dirt, and fix any abnormality. Replace the CR scale (SCALE, CR).Replace the CR encoder (BOARD ASSY., ENCODER, CR).
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
on Feb 23, 2016 | Epson Stylus Pro 3880 InkJet Plotter...
Error problem no E000061-0002
The laser shutter is faulty. The laser unit is faulty. The potential measurement
PCB is faulty. The DC controller PCB is faulty.
Mode of
Detection
0001 As the result of potential control, the drum surface potential (VL2)
of the white background is about 200 V (generating solid black images).
0002 The primary charging output used for print output and the drum
surface potential after laser output has been made are about 200 V
Feb 13, 2011 | Canon imageRUNNER 5000 Copier
What is maintenance code 0002 for epson stylus pro 7800 printer still working, just flashing code, cant find ansure to what the code is. Thanks Jim
Maintenance Code 0002 - Carriage Motor/Ink Tube is near end of life (Clear Carriage
Motor Counter)
If you clear the carriage motor counter it should work until the part expires.
Dec 17, 2010 | Office Equipment & Supplies
Hello I hae a problem with my EPSON Stylus Pro 7800 it said maintenace request 0002 what I have to do for solving it
Its more of a fiddly job than a difficult one. Remove both end covers and drop down the tray which has the mainboard on. Loosen the tension on the carriage belt, remembering to check the belt tension on the scale before doing so, then remove the belt from the pinion of the motor. Unplug the connector for the motor from the mainboard, then undo the cable from all the various clips and pieces of tape up towards the motor. Then remove the motor and do it all again in reverse. Once its installed you will need to reset the counter to clear the error message.
Oct 15, 2010 | Epson Stylus Pro 7800 InkJet Printer
Error code 354-0002 ir7200 serial number pcb
when you changed the main controller for the copier did you use the counter board that was on the old main controller or did you put the counter board from the old one on the new one.... if you don't use the old counter board with the new main controller then that problem will occure
May 19, 2010 | Canon imageRUNNER 7200 Copier
Error Code E000514-0002
514-0002 is a finisher error in the finisher
The delivery belt does not return to home position when the stack delivery motor is driven for 3 sec.
Main problem The stack delivery motor is faulty. The delivery belt home position motor is faulty.
Try to check motor & sensor or operate copier without finisher.
Dec 16, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
Solve error 5100.cannon pixma 145 error always out # 5100
5100 error is a carriage error. Could be caused by the carriage unit, timing strip, logic board or carriage motor. Check that nothing is obstructing the carriage from moving freely and that the clear timing strip is ok.
Nov 20, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Epson Stylus Pro 7400/7800/9400/9800 Matte Black 220 Ml Logo
Top Epson Office Equipment & Supplies Experts
Ekse
Muntejaya Ginting
Muntejaya Ginting
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
