SOURCE: batteries are dead can't open safe
I had the same problem. We finally located where the batteries were hidden. They were below the keypad, There is a silver, plastic cover that slides to the right to expose the 4 AA batteries. Hope this helps you.
SOURCE: gun safe, can't open it.
on the key pad bottom edge right above the nob are 2 half moons - this is for touching a new 9 volt to the metal and power the unit to input your code and open it - then replace battery.
SOURCE: Sentry S3807 safe-cannot open
locksmiths agree on how to install sentury safe batteries
slide open the battery cover located just below the keypad.
Insert a paper clip or pen point into the small hole in the cover. Push in while sliding cover to the right. Disconnect and remove the battery holder. Insert the 4-batteries as indicated.
reconnect the connector and put back the battery holder. Slide the cover back in place.
How do I insert the batteries on my advanced electronic lock safe?
to install batteries, turn the electronic lock case to the right and remove.Insert four new batteries as indicated, replace the electronic lock case and turn to the left to reassemble.
