Question about Danby DWM5500W-1 Energy Star 1.69 Cu.Ft. Front Load Washer
AEG LAVERMAT hOW TO REPLACE THE DOORLOCK MECHANISM
Posted by Harty on
  • 3 more comments
  • Bianca13 Jan 16, 2008
    The door handle has broken off
  • 1948pilot Jan 27, 2008
    Harty
    We have the same problem with our 5W5l30D Supra - It has been a great unit but the door handle broke off and now it is difficult to use - to say the least. I think that I could fix it if I could find a new mechanism but can't locate the parts. This unit is on a boat and the idea of a service tech making it down to the docks just doesn't work.
    Anyone know of a parts depot?
    Dave
  • Anonymous Feb 21, 2008
    handle broke & needs replaced Where can I get parts for this machine
    Splendide 2000S
  • Anonymous Mar 22, 2008
    Same Problem as described in the initial complaint. Same model.
  • redhills May 11, 2010
    Where do I find a replacement door hadle for a Danby DWM5500W-1?
J_TOTH00
  • 3 Answers
Thank you for your inquiry with Reliable Parts. Your research is as follows.
DOOR HANDLE FOR DANBY MODEL DWM5500W-1
Part number: 660137
Price: $ 6.99
Availability: in stock
All items need to be prepaid with a visa or a master card. No returns on electrical items, factory orders or damaged parts. All other returns are subject to a 20% restock charge. No returns accepted after 90 days from the date of purchase. Please add $4.95 for special factory orders. If you would like to order the part online, please visit our website and type in the part number in the quick find box. From there you can add to a shopping cart and check out online 24/7 If you have any other questions or for phone orders you can contact us at the numbers listed below.
Thanks again Shane Lyth
Reliable Parts
206-575-1791
[email protected]
1-800-666-0313 ext 1791
Online customer has requested assistance for the following part search:
Brand Name: Danby
Item Description: WASHER DOOR HANDLE
Model & Serial Number and Full Description:
DANBY MODEL DWM5500W-1 FRONT LOAD WASHER THE DOOR HANDLE BROKE OFF . THE LOCK MECHANISM STILL GOOD. NEED ONLY THE PLASTIC PART OF THE DOOR , WHERE THE HANDLE IS ATTACHED. THE SEE THROUGH WINDOW IS GOOD.
Posted on Oct 02, 2008
I have massage say D/Lock and I can't open the washing machine I have DWC-LD1013
The doorlock mechanism is most likely bad and will need to be replaced
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Sep 25, 2016 | Washing Machines
How to open door on2000 mercedes s 500 door deos't open from inside or outside
Thats a real pickle but you have to somehow get the door open without damage and remove the door panel and then replace mechanism controlling doorlock
Aug 02, 2013 | 1999 Volkswagen Passat
Door will not lock so it will not extract
Doorlock mechanism sounds like it needs replacing if it won't energise.
May 28, 2010 | Maytag Neptune MAH5500B Front Load Washer
AEG 6200 Washing machine punping water out of the
Please have the mechanical seal at the bottom
replaced. It is already leaking.
Sep 23, 2009 | Washing Machines
Renault laguna tailgate not opening all doors ok and rear window with wiper ok
Usually just one of the linking rods that got unhooked, or a doorlock motor that is now malfunctionning. You need to take apart the plastics and covers on the inside of the tailgate to have a clear view of the mechanism and pinpoint the rod that's not working, or pinpoint the motor for the doorlock to test it out. Be warned though, in some cases the tailgate needs to be opened to take the covers off. If you feel like they won't come off at all and don't see any screws left to take out, don't pry too much so you don't break it, and take it to the dealer to get them to open it up. It may cost a bit more, but at least if they break it while taking it off, they're gonna pay to replace it and they will also fix it.
Jul 03, 2009 | 2002 Renault Sportwagon
Looking for replacement switch
You would have to send me the old switch so that I can locate one
Apr 16, 2009 | Jenn-Air JDS9865BDP Stainless Steel Dual...
Door latch has broken and is stuck inside locking mechanism
I'm not familiar with non-US models, but you would probably have to use needle nose pliers to pull it out.
If that won't work, you'd have to remove the outer cover of the oven, and then you can see how the door latch heads (the hook-like devices sticking out of the door) interact with the door latches and the opening mechanism.
Then you can call AEG at the number in your manual to see if they will sell replacement parts.
If you don't have the manual / IFU, then I would suggest contacting the manager at the dealership from which you purchased the oven to see if they have contact info for AEG.
To replace your latch heads, normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
Oct 19, 2008 | AEG MCD343EUM 750 Watts Microwave Oven
AEG 16810 UPGRADE WASHER DRYER E10 ERROR
This is worth posting in case anyone else has the problem. The mechanic was stumped and then around 3 days later a Zanussi gave the same problem - steam emitting from the drum. He changed the valve - the entire unit. Problem solved. Zanussi and AEG have identical internals. He changed our valve - problem solved.
Jul 22, 2008 | AEG Lavamat 16810 Front Load Washer/Dryer
Indesit WG1235T O
I would say the doorlock switch is faulty
Oct 21, 2007 | AEG Lavamat 72640 Front Load Washer
Doorlock light keeps flashing.
poss the interlock or the module has gone I have found that the neutral suppy on the board to the interlock can breakdown if the module has gone call an expert has these modules when new need to be configured to your machine as 1 module can serve about 10 models
May 26, 2007 | Hotpoint Aquarius WMA42 Front Load Washer
Danby DWM5500W-1 Energy Star 1.69 Cu.Ft. Front Load Washer Logo
209 people viewed this question
Top Danby Washing Machines Experts
peter gittos
peter gittos
Marvin
Marvin
Mike
Are you a Danby Washing Machine Expert? Answer questions, earn points and help others
