SOURCE: Clean Light Flashes
I found this post elsewhere. It seems to have worked for me:
Our KitchenAid KUDP series dishwasher went into a mode where it would not start and would only respond to the cancel/drain button. The clean light would flash 7 times in a row, stop, and then repeat. I read that the 7 flashes indicates an error code and that the dishwasher has detected a problem in the heater element circuit. I tried to reset the error mode by turning off power for 15 minutes, however, that did not work.
We called for a repair. The service person found that the dishwasher was completely fine except that it had gone into an error mode. The technician reset the error mode and charge us $115.00.
The reset sequence used was reported to be the following:
1) Crack the door open.
2) Within 3 seconds press the following sequence - Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry
3) Close and latch the door
4) Press the cancel button (the circle with the triangle in it)
We were told the dishwasher expects to see the dish water temperature rise in a certain way. If the water does not heat in this way, the dishwasher becomes confused and thinks the heater element has failed. In deed, this happened just following and extended power failure and our hot water tank was cool. I am curious if this code will work for anybody else with the same problem and save a service call and 115 bucks. Overall, this seems to be a serious logic flaw in the design.
SOURCE: Blinking Clean Light
run the 'normal' cycle without the hi temp feature
SOURCE: Dishwasher Reset / Diagnostics
Unscrew and remove the kickplate at the very bottom of the dishwasher. The tech sheet with the diagnostic code should be attached to the back of it. If not, due a websearch and you should be able to find the info on yahoo or google.
SOURCE: Kitchenaid KUDS01FLBL2 dishwasher will not run
Juan, I found this http://fixitnow.com/wp/2007/01/20/blinking-clean-light-on-whirlpool-built-dishwashers/
It should help you out with the issue you are having with your dishwasher. Watch the video too!
Best of luck
SOURCE: my KitchenAid dishwasher will not run. Start light is blinking
Make sure the controls are not locked. Some units have the ability to lock the controls so that kids cannot turn on the dishwaher. You can also try unpugging the power to the unit from under the sink for about 10 minutes and then plug it back in. This may reset the control board if it has a fault and stopped from error code.
