Loud whining noise, have changed power supply already
SOURCE: Gigabyte GA-8LD533 Motherboard driver not found
plz check the following website
http://www.gigabyte.com.tw/Support/Motherboard/Driver_List.aspx
http://www.gigabyte.com.tw/Support/Motherboard/Driver_Model.aspx?ProductID=1402
SOURCE: gigabyte motherboard GA-8KNxp will not power up
If you have just installed a new mother board, refer to your manual and double check your connections for pwr switch. If this is a machine you've had for a while and it just stopped powering up then your power supply is probably broken.
SOURCE: Can Gigabyte GA-8I945PLGE-RH supports 4gb ram?
Sorry, but at the moment you can't do that. This is because the BIOS is programmed to manage only 2GB memory. I searched for BIOS upgrade to resolve the memory issue but with no luck. At the moment your motherboard supports only 2 GB RAM.
SOURCE: gigabyte ga-81915 pmd motherboard/precott 3.6 cpu/upgrade cpu?
the best and cheapest up grade is RAM.
Make sure you have all the memory your machine can handle.
A quick look say it can handle Core™ 2 Extreme QX9770(3.2GHz,12 MB)
And it has a PCI-express slot so you have a big chiose of video cards.Are you using the machine for gaming?
Testimonial: "Sounds good to me. No gaming.Thanks."
