Question about Kenmore 62622 Microwave Oven
How do you repair the surface light on microwave
Light "popped" under the microwave - replacement bulb does not light. think the socket is bad? or fuse??
Ronald Rissel
    Master:
  • Kenmore Master
  • 713 Answers
You know how when you turn on a regular light bulb and it burns out with a bright flash? What happens is that when the filament burns out, it breaks and bounces back and hits the other electrical post and basically shorts out causing that bright flash. Sometimes, when the light bulb in the microwave burned out, it shorted out, and caused the circuit-board trace to burn up. (This is not just conjecture; I've seen it.) If that's the case, then you would have to replace the main control circuit board. Unfortunately, a rather expensive repair for no lights. (Although the circuit board trace can usually be repaired by direct-soldering a wire to replace the burned trace. Sears repairmen won't do this, but an independent electronic technician could do it.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Posted on Jan 25, 2015
4 Related Answers
Anonymous
  • 32 Answers
SOURCE: Kenmore over range microwave oven / no power at all
Unfortunately, there is a good chance that when the bulb shorted out, it damaged the control board. The only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance. The relays for the fan and the lights are part of the board. The power should always be disconnected when these bulbs are replaced or the board will be damaged. We would have an appliance repair person take a look to see what the deal is with the microwave.
Go here for Kenmore Microwave Parts: http://www.repairclinic.com/Kenmore-Microwave-Parts
www.RepairClinic.com
Posted on Feb 05, 2009
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: light no longer works
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or no bright, too. Sometimes this will similarly affect the exhaust fan operation or inside light, too.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
[email protected]
http://www.microwavedisplay.com
Posted on Jul 20, 2009
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: kenmore microwave nights light don't work.
That's a problem on the circuit board which can be repaired simply and inexpensively.
A YouTube video showing how to remove a typical over the range control panel assembly in under 5 minutes, is here.
Posted on Dec 01, 2012
Testimonial: "Thanks for the info not sure if i want to deal with removing the board right now.Not sure who to ship to if i do."
Went to replace the bulb under the microwave and there was a loud 'pop'. Then the microwave was dead. Did not trip the breaker, and checked the fuse inside the microwave, and it is still fine, and so is...
< -- I see and repair this on a regular basis. Details are here .
This failure occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line, as the warning label near the light socket advises.
Feel free to contact me for more information.
Feb 16, 2014 | Goldstar MV-1501 Microwave Oven
My microwave heats, but the surface light and interior light don't light up and the turn table doesn't rotate. Everything else seems to be working fine. What is the best way to trouble shoot the problem?
follow this steps and fix it. God bless you
  • Light bulbIf your microwave light bulb is not working, perhaps it has blown. The first step is to replace the bulb and power on the microwave. If this does not correct the issue, the next step is to check the socket and wiring to verify if that is the problem.
  • Light bulb socket & main control boardIf your microwave light bulb is not working after the installation of a new bulb, check the light socket as well as the wiring to ensure they are properly operating. If these sources are functioning properly, the next step is to check for a faulty control board as a possible root cause to your microwave light bulb malfunction
  • Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#6#ixzz2gUUt9D8f
    Sep 30, 2013 | Microwave Ovens
    Lights under microwave went out. Replaced the bulbs and bulbs work fine, however, now the "surface light button" will not work. Pushing the button will not turn off the lights. Lights continuously stay on...
    This can often also affect the exhaust fan, cooling fan, turntable, and/or inside light operation, too.
    Details of our service are at our Web site, along with a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
    Feel free to contact me directly with your brand, full model number and symptoms.
    William E. Miller
    [email protected]
    Apr 26, 2010 | GE JVM1653 Microwave Oven
    Surface light dimmer not working for spacesaver microwave
    The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
    At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
    Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa.
    Feel free to contact me directly (and please remind me of your full model number) for more information & help.
    William E. Miller
    [email protected]
    Dec 02, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
    JVM1460 surface light problem
    We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid.
    This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
    Feel free to contact me directly for more information & help.
    William E. Miller
    [email protected]
    Aug 26, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
    Surface Lights Don't Work
    We regularly repair these control board assemblies for only $32.50 nationwide, and that's much cheaper than replacing the board. For safety, disassembly and other info see http://tinyurl.com/yzjozk
    Jan 14, 2007 | GE JVM1650 1000 Watts Microwave Oven
    Surface lights
    I also have had a problem with the glass part of the surface light bulb separating from the metal base when trying to change the bulbs under my G.E. Spacemaker Microwave.. I see someone used a carrot or potato but I had not seen this suggestion before I whittled one end of a wine cork small enough to insert into the metal part of the old bulb stuck in the socket. It also worked great and in no time I was able to get the old base out and replace the bulb. I'll save the cork for next time because it seems to happen to at least one of the bulbs everytime they need to be changed. DON'T FORGET TO UNPLUG THE MICROWAVE FIRST!
    Sep 05, 2006 | GE Spacemaker JVM1640SJ Microwave Oven
    Kenmore 62622 Microwave Oven Logo
    117 people viewed this question
    Top Kenmore Microwave Ovens Experts
    William Miller
    William Miller
    Michael Thomas
    Michael Thomas
    Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
