SOURCE: Toshiba 36AF41 36" TV no red color
Go to your menu/settings from the remote (or buttons on the tv, if applicable). And find the color or saturation settings, play around with those. If that doesn't work, your tv is dead, get a new one.
SOURCE: 36" toshiba suddenly turns off and the little red light flashes
Some el.components are loose on tv circuit board.I have removed the back cover,supported tv picture tube 45 deg.against wall.This tv is heavy!One screw on left holds the circuit board to bottom case.Removed and supported this board on few heavy books.Turned tv on and gently probed all the componets on top of the board with plastic drinking straw.In my case transistors Q-830 and Q-421 needed resolder loose joints.These components are mounted on flat aluminium heat sink strips located sligtly left of center of the circuit board.Also blobed bit of silicone into base hole and foot of alu.heat sink to support it.
SOURCE: Toshiba 36A42 36'' T.V.
A common cause is a failure in the one of the scan amplifiers or on the high voltage section. It is also possible to have a power supply fault that will give this error message.
Jerry G.
SOURCE: picture on 36 inch toshiba tv out
I had the same problem on my 61" RCA TV... The switch for the power/channel changing buttons seems to be a faulty product... However if you are a little technical you can open up the front of the TV and disconnect the button panel from the tv and just use the remote to operate it.
