Question about Samsung SCX3405FW - SCX-3405FW Wireless Multifunction Laser Printer, C
Samsung scx3405fw scanning margin issues
When using the scanner, it cuts off the top and/or bottom headers? Any sollutions
HEMANT GROVER
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Samsung Expert
  • 171 Answers
Check paper size in scan settings
Posted on Oct 02, 2015
Putting in the antifreeze
remove header tank cap undo drain plug at bottom of radiator and bleed screw at top of radiator once all coolant has drained retighten tthe drain plug pour the new coolant into the header tank waiting for the coolant to drain through system and watch for coolant to come out of the bleed screw , shut bleed screw top up the header tank to the max level replace cap.Now run engine ,dont drive just stay with revs at 1500 open bleed screw to let any trapped air out and wait for the cooling fan to cut in , allow engine to cool down and refill header tank if required and repeat the running/bleeding/fancutting in procedure until when engine has cooled the coolant is near the max mark on header tank
Apr 09, 2014 | Fiat Palio Cars & Trucks
Printer cutting off words
Is this happening with every program you use to print? If it's just a single program, try changing the line spacing. It sounds as if you've got the line spacing too small for the current font and it's cutting off the bottoms in order to print the next line.
Jun 10, 2013 | Canon Pixma Mp530 Office All-In-One Inkjet...
K9n6pgm2-v pin out
MSI Support > K9N6PGM2-V motherboard > Main Support page,
http://www.msi.com/product/mb/K9N6PGM2-V.html
Hover your mouse cursor on the Download tab.
(Overview / Specification / Download / Support / etc)
In the drop down list click on - Manual
Now click on the blue -> M7309V1.2.zip
Click on the country name nearest yours.
A small window will come up on the right -
Opening M7309v1.2.zip
Make SURE there is a Green dot in the small circle, to the left of Save File.
If not left-click once in the small empty circle, to the left of Save File
Now go below in the window, and click on OK.
A small window will come up on the left. Allow the file to download all the way.
Now DOUBLE-click right on the file name.
In the next small window go to the left side, and click on -
Extract all files
At the bottom of the next three small windows, left-click on
Next, Next, and Finish.
In the last small window go to the file name next to the red Adobe PDF icon, and DOUBLE-click on it.
7309v1.2(G52-73091X3)
There is your motherboard manual in PDF file form.
( Plus + icon increases the view size when you click on it.
Minus - icon decreases the view size.
When I refer to a page number it will be for the PDF reader, and not the actual manual's page )
Go to Page 8.
Motherboard Layout
The front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the main wires from the Front Panel go to, is the Front Panel header.
JFP1 is the Front Panel header.
JFP2 is an additional header. To be discussed after JFP1.
JFP1 is on the Right/Bottom corner. It is placed Vertically.
(Parallel to the right bottom edge of the motherboard)
Above it's left corner is JUSB2. (Front Panel USB header 2)
Above JUSB2 is the SATA2 connector. To the left of the SATA2 connector is the SATA1 connector.
To the left of the SATA1 connector is the CMOS battery.
The contact pins are arranged in two columns.
4 pins on the Left side, 5 pins on the Right side.
Go to Page 14. JFP1 pinout, and JFP2 pinout, is at the Bottom of the page.
JFP1:
Starting on the Bottom going towards the Top, Right side;
Pins 1, 3, 5, 7, and 9
Starting at the Bottom going towards the Top, Left side'
Pins 2, 4, 6, and 8.
A) Pins 1 and 3 are for the HarDDrive activity LED. (Light)
Pin 1 is for the Positive ( + ) wire.
IF the HDD LED is dim when the harddrive is active, switch the wires around.
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
C) Pin 9 is N/C. Not Connected. (Probably 5 Volts positive, and used by the factory only)
D) Pins 2 and 4 are for the Power On LED. (Light)
Pin 2 is for the Positive ( + ) wire.
IF the PWR ON LED is dim when the computer is on, switch the wires around.
E) Pins 6 and 8 are for the Power On switch.
JFP2:
Below JFP1 is a header that is placed Horizontally. It is parallel to the Bottom edge of the motherboard. This header with 13 pins in it, is the JLPC1 header.
(Starting on left side at the Top row; 4 pins, no pin, 2 pins.
Starting on the left side at the Bottom row; 7 pins)
To the left of the JLPC1 header is the JFP2 header.
4 pins across the Top row, 3 pins across the Bottom row.
The top 4 pins across the top are for an internal speaker. Used to hear BIOS Beep Codes.
Starting on the Left side coming towards the Right, top row;
No indication of polarity.
Believe pin 2 is for the Positive wire, and pin 8 is for the Negative wire.
Starting on the Left side coming towards the Right, Bottom row:
Pins 1, 3, and 5.
These pins are ONLY used for a Power On LED light, that has 3 wires.
Used for a dual color Power On LED.
(One example; Green Turbo, Yellow normal)
The rest of the pinouts are listed in the manual.
Have additional questions? Post in a Comment.
I also downloaded the manual.
Regards,
joecoolvette
Oct 16, 2012 | MSI K9N6PGM2-V Motherboard
How to connect power to the front panel
Power to the Front Panel?
A) The plastic front of your computer is the Front Panel
B) The area of pins sticking up on the motherboard, that the wires from the Front Panel go to, is the Front Panel header.
I believe what you are requesting is the Front Panel header pinout.
AsRock Support > AsRock 775i65GV Motherboard > Main Support Page,
http://www.asrock.com/MB/overview.asp?Model=775i65GV
Go to the headings on the upper left side.
Products, Motherboard Series, 775i65GV, Overview and Specifications, and so on. Click on - Manual
On the next page go across from the heading - User Manual, and click on - Click Here, under the country nearest yours.
Disregard if you are aware;
This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click it may take up to 30 seconds before the first page comes up.
At the top of the PDF file is the page number box. It is to the right of the Down Arrow.
You can use the Down Arrow to arrive at the page you want, or;
1) Put your mouse cursor in the page number box.
2) Left-click once. (Contents in page number box will be highlighted in blue)
3) Type the page number you want in the page number box.
4) Press the Enter key
Go to Page 10
This page shows an illustration of the motherboard, and as it sits in your computer case.
To the bottom Right corner is the Front Panel header. It is marked by the number - 16 [ System Panel Header ( PANEL_1) ]
{ It is the second header over from the Right side. It is Black in color. The first header is a USB header, and it is Blue }
Now go to Page 22. Front Panel Header Pinout. (System Panel Header pinout)
If you cannot download this motherboard manual, or if you do not understand the pinout;
There are 4 pins across the Top row.
There are 5 pins across the Bottom row.
The Top row of pins are numbered Even
The Bottom row of pins are numbered Odd.
Starting at the LEFT side going to the Right, on the Top row;
Starting at the LEFT side going to the Right, on the Bottom row;
Pins 1, 3, 5, 7, and 9.
A) Pins 1 and 3 are for the HarDDrive Activity LED light.
IF the LED light is dim when operating, switch the two wires around.
B) Pins 5 and 7 are for a Reset Switch, IF, a Reset switch is used.
Pin 5 is for Ground ( - )
C) Pin 9 is Not Connected. (N/C)
D) Pins 2 and 4 are for the Power On LED light.
If the LED light is dim, switch the two wires around.
Page 21 details out the USB front panel headers, (USB 2.0 Header, Shared USB 2.0 Header), and the Front Panel Audio Header.
For additional questions please post in a Comment.
Regards,
joecoolvette
Dec 26, 2011 | Asrock 775i65GV Motherboard
Intel D848PMB MOTHERBOARD PANEL
I would like you to download the Motherboard Manual for the Intel D848PMB mobo, from Intel,
(Mobo = MOtherBOard),
http://www.intel.com/support/motherboards/desktop/d848pmb/sb/cs-008915.htm?wapkw=%28Intel+D848PMB%29
On this page click on the first file listed.
Click on the blue - Product Guide - PDF, above the file name,
File Name: D848PMB_ProductGuide_English02.pdf
It may take as long as 30 seconds before you see the first page. It may also take additional time to fully download the file.
This is just a temporary download so that you can view the file. (Manual)
There is a way to download it to your computer for safekeeping.
(This way you can also burn a copy to a CD disk, and delete it from your computer to save harddrive space)
If you do not know how, and wish to, please state in a Comment.
Orient the motherboard in your mind, so that we are both looking at it in the same direction.
With the computer case open the motherboard will be sitting in this direction;
Processor to the top, (Processor fan on top of Processor), Ram Memory to the right, and the white PCI slots (3) are to the bottom.
The Front Panel header is located at the bottom Right corner. It is situated on the Right side.
(The plastic front of your computer is the Front Panel. The area of pins on the motherboard that the Front Panel cable, (Wires), connect to is the Front Panel Header)
There is two columns of pins. The header itself is vertical, (Parallel to the Right side), with pins arranged in two's going down the header.
In the Motherboard Manual (Product Guide) on Page 12, the letter S points to the Front Panel header.
The Front Panel header's pins are numbered. The numbering begins from the BOTTOM of the motherboard, and increases going towards the top.
(Page 35. The letter E points at the Front Panel header.
It is also named J9H3. Junction 9 Header 3)
Bottom RIGHT column starting from the BOTTOM of the motherboard, going towards the top,
Bottom LEFT column starting from the BOTTOM of the motherboard, going towards the top,
Pins 2, 4, 6, and 8. (There is NO Pin 10)
Page 36,
1) Pins 1 and 3 are for the HarDDrive Activity LED light. (Blinks when the harddrive is active, and in use)
2) Pins 5 , 7, and 9 are for a Reset switch. (Reset button)
This is IF a reset switch is used.
(This is what CTRL, ALT and DELete are for)
3) Pins 2 and 4 are for the Power On LED light.
[NOTE*
If the HDD Activity LED light, or the Power On LED light are dim, switch the wires around]
4) Pins 6 and 8 are for the Power On switch.
Regards,
joecoolvette
Jun 16, 2011 | Computers & Internet
I AM REPLACING THE HEADER IN H250FDN HEATER. NEW HEADER INSTRUCTIONS MATCH OLD HEADER AND NUMBERS MATCH ON OLD AND NEW BUT NEW HEADER IS DIFFERENT. OLD HEADER HAS 2 LIMIT ON BOTTOM NEW ONE HAS 1 ON BOTTOM...
As long as it still has 2 hi limit switches, this will be easy.
You will need one wire going from one limit switch to the other. (on any terminal)
take either of the incoming wires from the old limit wiring and connect to second terminal on either limit switch.
Now take the last remaining wire and connect ot to the last terminal on the second limit switch.
Basically, you are just creating a bridge. Power will go into first limit switch, then go into the second limit switch via the first wire indicated above. Then the power will go back out to the pc board. If a high limit switch trips, then power is cut off (cicuit opens) and it tells the cpu there is a problem and shuts down the heater.
So to simplify: connect the wire in between the two limit switches. Then put the other 2 wires anywhere.
May 04, 2011 | Hayward 250fdn Low Nox Nat Gas Swimming...
Cut or copy and paste does not work
That is very common problem and there is no one-best-sollution for it since they are tons of possible reasons.
Possible sollutions:
#1 close all programs
#2 switch off->switch ON pc
#3 scan for possible malware using antivirus software
#4 try using keyboard shortcuts crtl+c = copy or ctrl-x = cut
Leave rate if I helped you, thanks!!
Cheers,
Mike
May 09, 2010 | Microsoft Windows Vista Ultimate Edition
Emachine W3410,the main three wire from the motherboard to the power botton on and off switch was remove and iam not sure wish pin they go to .power led, power sw, H.D.D.led,
The eMachines W3410 uses an MSI ms-7145 motherboard.
Also known as RS480M
This is MSI Support, and the download page for the motherboard manual, for the RS480M motherboard,
http://www.msi.com/index.php?func=proddesc&maincat_no=1&prod_no=204
To the Right of the photo of the motherboard, you will see a gray bar with, BIOS, Driver, Utility, Manual, and RSS.
Left-click on Manual.
On the next page look under the heading to the right - Document.
Left-click on the blue - E7145v2.1.zip
On the final page click on the country nearest yours.
A small window will come up with the heading -
Opening E7145v2.1.zip
Be sure that Save File has a green dot, in the empty circle to the left.
[If not, Left-click on the empty circle to the left of Save File]
Now click on OK, below.
Where this file will go.
If you Do Not, have your documents set to save to your My Documents folder (Documents for Vista), the file will go to your desktop screen.
In either place Double-click on the file. Now go up to the left, and click on - Extract All Files.
Click on Next, and Finish.
You will now see a PDF icon. Double-click on this icon.
Go to Page 15.
The plastic panel on the front of your computer is the Front Panel.
This is where the Power On switch, Power On LED, and HDD LED are located.
The connector on the motherboard where the cables (Wires) attach to, is the Front Panel header.
The front panel header is a series of pins, sticking up out of the motherboard.
The MSI ms-7145 motherboard, (RS480M) has the Front Panel header separated into two headers.
JFP1, and JFP2
Looking at the motherboard with the Processor socket to the top, and the Ram Memory slots to the right, the JFP1, and JFP2 front panel headers are located at the extreme bottom Right, of the motherboard.
[Use the Zoom In feature (+ at top of file) to enlarge the motherboard layout on Page 15]
Now go to Page 38.
Page 38 shows the connections for the JFP1, and JFP2 headers.
The JFP1 header, and the JFP2 header, consists of two rows of pins in a horizontal column.
The pins are arranged parallel, to the bottom edge of the motherboard.
Right above the JFP1, and JFP2 header may be three pins, with two of the pins have a jumper. We will not concern ourselves with this jumper header (BIOS with Protect Jumper)
The JFP1, and JFP2 headers are close together. There is no separation in-between them.
The JFP2 header is for an internal speaker.
The JFP1 header is for the Front Panel cables.
The JFP1 header pins start from the right side of the motherboard, and go towards the left.
There are 5 pins across the Bottom. (Going from right to left)
There is NO pin, then there are 4 pins across the Top.
(Again, going from Right towards the left)
The top row of pins are numbered Evenly.
The bottom row of pins are numbered Odd.
Starting on the Right side, going towards the left for the Top row of pins, the pins are numbered,
10 (NO pin for 10), 8, 6, 4, and 2.
Starting on the Right side, going towards the left for the Bottom row of pins, the pins are numbered,
9, 7, 5, 3, and 1.
1) Pins 2 and 4 are for the Power On LED.
2) Pins 6 and 8 are for the Power On switch
3) Pins 1 and 3 are for the HarDDrive activity LED
4) Pins 5 and 7 are used for a Reset switch. (If applicable)
5) Pin 9 is not used.
Apr 30, 2010 | E-Machines T3958 (827103050974) PC Desktop
Printer cuts off top 1 inch of PDF document
Go to the printer properties and try setting it up with border less printing.
Cheers
May 23, 2008 | Lexmark X4270 All-In-One InkJet Printer
Samsung SCX3405FW - SCX-3405FW Wireless Multifunction Laser Printer, C Logo
77 people viewed this question
Top Samsung Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Muntejaya Ginting
Muntejaya Ginting
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
