Question about Weiser Lock POWERBOLT ELEC DEADBOLT
How do I remove the cover to replace the batteries?
Where has the replacement battery CR1620 must be placed?
1) Open the main battery compartment
2) Remove the battery tray
3) Inside the battery compartment directly behind the LCD screen there is a small cover about the same size as the CR1620.
4) Remove the cover
5) Replace the battery
6) Replace the cover
7) Replace the battery tray
Jul 20, 2012 | Polaroid Battery Grip for Canon EOS-7D...
Tip
Nokia battery
<b>Remove the back cover</b><br /> Place the phone with the back of the phone facing you. Pull up the back cover from the finger grip at the top of the cover.<br /><br /><b>Note:</b> Always turn off the power, and disconnect the charger and any other device, before removing the cover. <a></a><span>Avoid touching electronic components while changing the cover.</span> Always store and use the device with the cover attached.<br /> <b>Remove the battery</b><br /> After you have removed the back cover, insert your finger into the finger grip, and lift the battery from its compartment.<br /> <b>Replace the battery</b><br /> <ol> <li>Insert the gold-colored contact end of the battery into the battery slot. </li> <li>Push down on the other end of the battery to snap it into place. </li></ol> <b>Replace the back cover</b><br /> Place the back cover on the phone bottom first so that the cover tabs align with the slots in the phone and press the cover moving from the bottom to top until the cover is securely in place.
on Mar 09, 2011 | Cell Phones
Replacing battery on Aston Martin Vanquish
Below is the procedure for an Aston Martin Vantage, perhaps the vanquish is similar?
Removal
1. Power the driver's fully forward.
2. Remove rear compartment cover.
3. Loosen and disconnect battery terminals, earth (- ve)
terminal first.
4. Release rear carpet, studs (x2), move carpet aside.
5. Remove screws (x2), battery compartment cover to
support rail.
6. Remove nuts (x2), battery compartment cover to body.
Remove cover.
7. Remove Torx screws (x4), remove battery clamps (x2).
8. Disconnect battery vent tube.
9. With assistance, remove battery.
Installation
1. Clean battery tray and clamps.
2. With assistance, install battery into its compartment.
3. Connect battery vent tube.
4. Position battery clamps (x2), install and torque tighten
Torx screws (x4).
5. Ensure battery vent tube is not distorted by battery.
6. Install battery terminals, tighten terminal nuts to correct
torque.
7. Install battery compartment cover, install and tighten
screws (x2) and nuts (x2).
8. Position rear carpet, secure with studs.
9. Install rear compartment cover.
10. Reposition driver's seat.
Courtesy of pistonheads.com
Please vote if this helps! Thanks, Mike
Jun 12, 2011 | Aston Martin Vanquish Cars & Trucks
How do you remove back cover to replace 296 wrist watch battery
Thank you for contacting FixYa.
  • Place the watch face-down on a clean towel to protect the crystal.
  • 2
    Gently unscrew the backplate from the watch with a small jeweler's screwdriver and set it aside.
  • 3
    Locate the battery compartment and remove the screw holding the cover in place, using the screwdriver. The battery is a small, round silvery button.
  • 4
    Make a note of the battery polarity before you remove it. Is the battery positive (+) side up or negative (-)?
  • 5
    Take the battery with you to a watch shop or electronics store to buy a replacement.
  • 6
    Insert the new battery in the compartment. Replace the battery cover and reverse the above steps to reattach the back cover of your Peugeot watch
  • Sep 14, 2010 | Peugeot Watches
    TI BA II battery change How do I do this without ruining the calculator!
    Turn off the calculator and turn it over with the back facing you. Using a small Phillips screwdriver, remove the four screws from the back cover. Carefully pry off the back cover. Using a small Phillips screwdriver, remove the screws from the metal battery cover and lift the cover off the battery. Tip the calculator slightly to remove the battery. Caution: Avoid contact with other calculator components. Install the new battery with the positive sign (+) sign down (not showing). Replace the battery cover and the screws that hold it in place. Align the screw holes in the back cover with those in the calculator, then snap the back cover onto the calculator. Replace the screws.
    The battery is a CR2032.
    May 26, 2010 | Texas Instruments BA-II Plus Calculator
    How to open Philips shaver 7110X to replace batery
    Remove 2 screws on the back to remove outer cover. Once removed, you will see 3 more screws that must be removed on the inner cover. Remove screws and cover to get to the battery.
    When installing the battery, I suggest that you use a modified installation technique. This is to break the tabs off of the old batteries rather that removing them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can them solder the tabs from the new batteries to the old existing tabs
    You will find a battery for your shaver at shaveroutlet.com. See link below.
    http://shaveroutlet.com/shaver-replacement-battery-aa-nimh-p-108.html
    Feb 12, 2010 | Philips 7110X Electric Shaver
    How do you open battery slot
    (1)Remove the USB connector cover.
    (2)Press and Move the battery cover in the direction of the arrow.
    (3)Remove the battery cover and insert one AAA-size battery into the
    battery compartment.
    (4)Replace the battery cover.
    Jan 23, 2010 | Nextar MA933A MP3 Player
    Replacing the cover for the batteries. I have the
    There is no instructions.Remove the cover nut's and keep those carefully.u can remove battery cover after that.
    Nov 01, 2009 | Canon PowerShot A40 Digital Camera
    PASSWORD
    Remove the RTC battery for at least 15 monutes then replace. Get into BIOS and reset date and time. Removing the Coin-Cell Battery
    1. Follow the instructions in Before You Begin.
    2. Remove the hinge cover (see Removing the Hinge Cover).
    3. Remove the keyboard (see Removing the Keyboard).
    4. Insert a plastic scribe into the guide on the side of the coin-cell battery compartment, and pry out the battery.
    Replacing the Coin-Cell Battery
    1. When you replace the battery, insert it at a 30-degree angle under the clip with the positive (identified by a plus [+] symbol) side up, and then push it into place.
    2. Replace the keyboard (see Replacing the Keyboard).
    3. Replace the hinge cover (see Replacing the Hinge Cover).
    Oct 02, 2009 | Dell Inspiron 1501 Notebook
    Got a new samsung j700 today but i cnnot remove the battery cover I bought a new Samsung behold cell phone today and can't remove the battery cover on the phone.
    Remove the battery cover. To do so, press the ridged area on the battery cover using your thumb (1) and gently slide it in the direction of the arrow (2). Remove the battery cover.
    Place the battery so that the three brass tabs on the end align with the three brass prongs at the bottom of the battery compartment (1). Press the battery down until it clicks into place (2).
    Replace the battery cover. Make sure that the battery is properly installed before switching on the handset.
    Thanks.
    Mar 27, 2009 | Samsung J700 Cellular Phone
    Weiser Lock POWERBOLT ELEC DEADBOLT Logo
    Top Weiser Lock Locks & Locksmithing Experts
    Scoee Scoffer
    john h
    Are you a Weiser Lock Lock and Locksmithing Expert? Answer questions, earn points and help others
