SOURCE: MAYTAG NEPTUNE LR CODE
LR usually means that the the signal from the board is not getting to the motor either because of a bad connection at either the motor or the board or the motor itself is no good. Need to check the connections first.
SOURCE: washer machine maytag neptune front load
take the back panel off,see if the belt has broke if not,check your motor control board for burn spots ,front bottom right inside washer,if not that then your motor has gotten weak and will not turn the drum,let me knoe what you find-mike
SOURCE: Maytag front loader MAH-3 vibrates. Level & on concrete floor.
THERE ARE SHOCK ABSORBERS IN THIS UNIT,SOUNDS LIKE ONE OF THEM IS BROKEN.HOPE THIS HELPS
SOURCE: maytag neptune washer MAH-1 start button turns off, does not spin
Hi!
Is it pumping water? If not then pump is bad.
Is the door locking? If the door will not lock, the washer will not enter a spin mode. See if the lock light is lite on the console.
Check for continuity across the Door Lock, Spin Enable Switch when the switch actuator button is pressed in. If there is no continuity across the Door Lock, Spin Enable Switch, replace the Door Lock Switch Assembly.(Check for 120 vac across the Door Lock Wax Motor)
Please rate this solution and ask for further clarifications if needed.
Thanks
Rylee
SOURCE: maytag neptune washer model mah6500a, took the
Looks like another motor/motor control panel replacement. This machine has a faulty motor/motor control board, it has been re-engineered with a replacement. Has yours been replaced? Have you found the tech sheet behind touch panel and placed machine in service mode to test? We had the same issue, worked sporadically, didn't drain, got LR code then eventually stopped working. Check your spin in service mode, if it doesn't spin properly you should find out here. It is a very simple repair in all actuality. Contact Maytag and they will sell you the parts for a discounted price, make sure that you buy directly from Maytag, also check your boot very carefully since that part will also fail and allow water to get into the bottom of the machine where you have electronics.
